Could you help to install the ST timer on the AT91Rm9200? I don't know how to setup the AIC registers correct. Maybe there are more than one big mistake.
void initialize_pit() { unsigned int flag, period, irq_id, mask, oldHandler, src_type, priority; volatile int status; void *newHandler; //period Timer0->ST_PIMR = period << 5; AT91F_ST_SetPeriodInterval(Timer0, period); //state //status = Timer0->ST_SR; //enable interrupt flag=1; Timer0->ST_IER = flag; AT91F_ST_EnableIt( Timer0, flag); //enable PMC AT91F_PMC_EnablePeriphClock(AT91C_BASE_PMC, 1 << AT91C_ID_IRQ0); //config AIC irq_id = 0; oldHandler = pAic->AIC_SVR[irq_id]; mask = 0x1 << irq_id; pAic->AIC_IDCR = mask ; pAic->AIC_SVR[irq_id] = (unsigned int) newHandler ; //* Store the Source Mode Register pAic->AIC_SMR[irq_id] = src_type | priority ; AT91F_AIC_ConfigureIt(pAic, irq_id, priority, src_type, newHandler); //enable AIC AT91F_AIC_EnableIt(pAic, 1); }
I hope somebody could help me with this problem...
best regards johannes
I'm just sitting in front of my code, which is not working. Could someone give me some advice or an simple example how to implement an timer for the AT91RM9200?
Your code doesn't show the definition/declaration of Timer0. If the problem is there, it's impossible for anyone not having access to the code to spot.
I'm not sure what this line is supposed to do. The AIC is continuously clocked (see device datasheet, p. 241, 22.6.2.).
irq_id = 0;
IRQ ID 0 is the interrupt of the AIC itself. The system interrupts have the IRQ ID 1. Refer to the device datasheet, p. 21.
I don't think the code assigns a value to newHandler anywhere. Basically, this sets the interrupt vector to a random address. That's a surefire way to get undefined behavior.
priority never has a value assigned to it anywhere. This doesn't just set the priority to a random value, it may also set the source type to a random value. Oh. src_type also never has a value assigned to it, either.
The code first tries to configure the interrupt "by hand" and then does so again by using the function.
thanks for your answer
AT91PS_ST Timer0;
enable the peripherie clock for the ST timer.
>The code first tries to configure the interrupt "by >hand" and then does so again by using the function.
it is enough to use this line of code?
I don't know what I have to use for "newHandler"? Moreover I changed the irq_id to 1.
Does Timer0 have a value assigned to it anywhere ? If it is just declared as a global variable, then its value will be 0 by default.
The system timer is continuously clocked (device datasheet, p. 294, 24.4.1).
The address of an interrupt service routine, which you'll most likely have to write yourself.
thanks...
Timer0 = 10000; //Periode für den Timer period = 5; AT91F_ST_SetPeriodInterval(Timer0, period); // Interrupt enablen - gesetzt wenn ST_IER=1 flag=1; AT91F_ST_EnableIt( Timer0, flag); //config AIC irq_id = 1; mask = 0x1 << irq_id; pAic->AIC_IDCR = mask ; pAic->AIC_SVR[irq_id] = (unsigned int) newHandler ; //* Store the Source Mode Register pAic->AIC_SMR[irq_id] = src_type | priority ; AT91F_AIC_ConfigureIt(pAic, irq_id, priority, src_type, newHandler); //enable AIC AT91F_AIC_EnableIt(pAic, irq_id);
Could you give me a small example for the newHandler?
Timer0 = AT91C_BASE_ST;
ok I only have to use such a function, which works,when the interrupt occurs - right?
void ST_interrupt(void) { AT91F_PIO_SetOutput(AT91C_BASE_PIOB, AT91B_LED1); AT91F_PIO_ClearOutput(AT91C_BASE_PIOB, AT91B_LED1); }
I'm afraid it is almost, but not quite that simple.
What an interrupt handler needs to do is explained in the device datasheet (I hope you have a copy of it), in the chapter about the AIC. An interrupt handler must, for example, indicate to the AIC that it has finished processing the current interrupt. The exact way to this (you guessed it) is described in the datasheet.
It is generally a very good idea to thoroughly read the chapters in the datasheet about the peripherals and features you are going to use. Some things aren't quite intuitive. And have a copy of the datasheet handy in order to read through the chapters again while programming the device.
thank for your answer - now this is my current code... could you tell me, what's wrong?
initialization of the pit timer
void initialize_pit() { unsigned int flag, period, irq_id, mask, src_type, priority; volatile int status; Timer0 = AT91C_BASE_ST; /* Base Address for the ST Timer */ //period for the pit timer period = 500; AT91F_ST_SetPeriodInterval(Timer0, period); // enable interrupts flag=1; AT91F_ST_EnableIt( Timer0, flag); //config AIC irq_id = 1; AT91F_AIC_ConfigureIt(pAic, irq_id, priority, src_type, ST_interrupt); //enable AIC AT91F_AIC_EnableIt(pAic, irq_id); }
pit timer interrupt handler
void ST_interrupt(void) { AT91C_BASE_AIC->AIC_IDCR = 0xFFFFFFFF; //disable all interrupts AT91C_BASE_AIC->AIC_ICCR = 0x00000001; // clear pit interrupt AT91F_PIO_SetOutput(AT91C_BASE_PIOC, AT91C_PIO_PC1); AT91F_PIO_ClearOutput(AT91C_BASE_PIOC, AT91C_PIO_PC1); AT91C_BASE_AIC->AIC_IECR = 0x00000001; // interrupt enable command AT91C_BASE_AIC->AIC_EOICR = 0x0; // end of interrupt }
main method
void timer() { unsigned int tick; // timer unsigned int pit_interval; // intveral pit timer initialize_pit(); *(AT91C_ST_PIMR) = pit_interval; // value for the pit timer tick = *(AT91C_ST_CRTR); //variable tick has the current value of the PIT timer while(1) { while (tick == *(AT91C_ST_CRTR)); tick = *(AT91C_ST_CRTR); } }
src_type and priority don't have any values assigned to them !
I'm pretty sure that the compiler is issuing warnings about variables being used before having been assigned a value here. Compiler warnings are there for a reason and usually indicate that there is a problem with your code.
This is unnecessary and useless at best. Since you probably want the ST interrupt to be level-sensitive, the AIC_ICCR will have no effect. The interrupt will be cleared by reading ST_SR instead.
You still have uninitialized variables. Have you turned on all compiler warnings, and then made sure to clean out any warnings you get?
Another thing:
Notice 1: The semicolon at the end of the while() line menas that you have a while statement with an empty body - the indented second line isn't part of the while loop...
Notice 2: Is your loop intended as a delay? If all you want is the tick variable to be updated when the timer steps, you should let the interrupt service routine (ISR) assign a new value to tick on each interrupt. But then again - if the specific register in the timer is tha value you need, there is no reason to make a copy of it to a variable.
ok - now I get no warnings or errors... but the call for the ST_interrupt routine doesn't work...
void timer() { unsigned int pit_interval; // intveral pit timer initialize_usart1(); initialize_pit(); *(AT91C_ST_PIMR) = pit_interval; // value for the pit timer while(1) { //do nothing } }
The ST_SR register tell's me only if there has been a interrupt since if red it the last time..
irq_id = 1; priority = 1; src_type = 0x01; AT91F_AIC_ConfigureIt(pAic, irq_id, priority, src_type, ST_interrupt);
that is my configuration for the AIC.
No - the ST_SR is the direct cause for the ST interrupt line being asserted. There's a "hard-wired" connection on the chip that says "(ST_SR AND ST_IMR) -> Status of the ST interrupt line.
You can find #defined values for the source type and the priority in AT91RM9200_inc.h.
0x01 for the source type isn't even a valid value, since the source type field consists of bits 5 and 6 in the AIC_SMR.
I set the value for the src_type to 1.
but what's the reason, that my ST_interrupt(void) method never run?
Is the only solution to say if(ST_SR == 1) go to ST_interrupt(void) ?
johannes
