hi there i am interfacing the v to f converter AD645 to 89s52 i am going to used this v to f converter as an ADC.but i trapped in some problem the value is not displayed on the display(7 SEGMENT)the routine for the display is working properly as i tried it with the test value following code give you the clear idea.
#include<reg52.h> #include<define.h> #include<intrins.h> /*****************function declaration***************************/ void disp_wait(void); void disp(unsigned int); unsigned int cal();//v2f /**********************************************************************/ unsigned char number_code[10] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};//7_seg unsigned int i,j,k,l,val;//7_seg unsigned int No_Of_Count,Over_Flow_Occours,No_In_Counter,No_In_CounterHI,No_In_CounterLO;//v2f unsigned int sec_1 = 0; //v2f /********************* interrupt setting (routine)*************************/ void TMR_1(void) interrupt 3 //v2f {Over_Flow_Occours++;} void TMR_0(void)interrupt 1 { TF0 = 0; //reload timer TR0 = 0; TH0 = 0x63; TL0 = 0xbf; disp(val); // call display sec_1++; // dec upto 1 sec if(sec_1 == 50) { sec_1 = 0; No_Of_Count = cal(); TR0 = 1; } else {TR0 = 1;} } void disp(unsigned int val) { unsigned int tempreg,i_digi,j_digi,k_digi,l_digi; unsigned int val_2,val_3; tempreg = val; i_digi = tempreg % 10; val_2 = tempreg / 10; i = i_digi; j_digi = val_2 % 10; val_3 = val_2 / 10; j = j_digi; k_digi = val_3 % 10; k = k_digi; l_digi = val_3 / 10; l= l_digi; DECOD1 = 0; DECOD2 = 0; DECOD3 = 0; P0 = number_code[i]; disp_wait(); DECOD1 = 1; DECOD2 = 0; DECOD3 = 0; P0 = number_code[j]; disp_wait(); DECOD1 = 0; DECOD2 = 1; DECOD3 = 0; P0 = number_code[k]; disp_wait(); DECOD1 = 1; DECOD2 = 1; DECOD3 = 0; P0 = number_code[l]; disp_wait(); } void main(void) { P0 = 0x3f; P1 = 0xff; P2 = 0xf8; P3 = 0xff; IE = 0x8A; TMOD = 0x51; /* Timer 0 as timer in mode 1 ; Timer 1 as counter in mode 1 */ TH0 = 0x63; TL0 = 0xbf; TR0 = 1; while(1) {} } /**************************dly routine's*******************************/ void disp_wait() { unsigned int w1=0; unsigned int w2=0; for(w1=0;w1<=20;w1++) { for(w2=0;w2<=22;w2++) {} } } /**********************************************************************/ unsigned int cal() { unsigned int w1 = 0; unsigned int w2 = 0; unsigned int Value;//count in 100 msec period Over_Flow_Occours = 0x00; TR1 = 1; // run countrer and give dly for 100 msec for(w1 = 1;w1<=40;w1++) { for(w2 = 1;w2<=930;w2++) {} } TR1 = 0; // stop the counter TH1 = ACC; // get value from TH1 to ACC ACC = No_In_CounterHI; // move value(HI) form ACC to No_In_CounterHI No_In_CounterHI = No_In_CounterHI * 100; TL1 = ACC; ACC = No_In_CounterLO; // move value(LO)form ACC to No_In_CounterLO No_In_Counter = No_In_CounterHI + No_In_CounterLO; Value =(Over_Flow_Occours*512) + (No_In_Counter);//calculation for no of count. Value = 2345 ; //test value val = Value;//No_In_Counter; return(val); // return No_In_Counter [No_In_Counter == vtg] }
for ad654 click on www.analog.com/.../AD654.pdf page no. 8 and 9 will give you the clear idea
