I had declared an variablw like below,
unsigned int i;
Normally the data representation may be in either decimal or hexadecimal.
In my project the value of 'i' is decimal i need that unsigned integer of decimal form to hexadecimal.
I coudnt use _toacii function since it is truncating the upper nibble of the decimal int.
Can anybody say is there any way to get the equivalent hex of the original decimal integer.
www.permadi.com/.../
Jon
Thank you.
I know this method to get the hex from dec.
But iam not sure how to combine all the remainders to a single int of hex?
Is there any C code for this?
In my project the value of 'i' is decimal .
No, it's not. You may have some number given in ASCII-coded decimal, but that's not the "value of 'i'". You need to go back to your C textbook and learn what a variable is, and what its value means.
