I did a couple of searches and found some references to the problems I am having. But I don't think this is fully addressed, so I'll ask here.
I am using the contest eval board from Luminary Micro that includes an eval copy of the Keil tools for the Cortex-M3. I have seen variables in the local watch window display the wrong value as I step through a program. There are a couple of threads here from last summer about this, so I guess this is a known (and fixed) problem. I am surprised they circulated an old version of the tools for this contest. I just got my board in early December.
The other problem is that in one case, I was not able to view a variable in a watch window. It was a local variable and did not show in the Locals window. I also could not add it to the other Watch windows. This variable was being used, so it should not have been optimized away. I was compiling at optimization level 0, so that should not be the problem. Is this a known problem? Is it fixed in a current version of the tools?
Rick, does this problem occur with OPTIMZE level 0 too? The issue is that sometimes local variables are optimized away and it is therefore not possible to diplay them.
Yes, I have only been using optimize level 0 so far. But as I near completion, my project is growing and may exceed the 16 kB limit for the contest tools. I may then have to start using higher levels of optimization.
I am *not* using the newest version of the tools. I am using the version that was shipped with the Luminary Micro contest eval board. There is an update available which I have not had the chance to install yet. Even this version may not be the same as is currently being shipped by Keil.
Also, I would like to point out that I am having two different problems. One may have to do with variables being "optimized" out. The other has to do with the variable display in the Local watch window showing wrong data because the register assignment has changed. Is this a known bug? All problems are exhibited at optimize level 0.
Rick,
I had the same problem too, the one where the data displayed in the 'locals' watch window had no bearing at all on what the real value of the variable was. I seem to recall that when I reported this to KEIL in the form of a bug report the answer I got back was something like "it's harder to keep all these variables and the values for them right than you might think, plus, our optimizer optimizes too well even at it's lowest possible setting, we're working on it." I tried all sorts of things, but I never could get this problem satisfactorily resolved. I gave up on the debugger and went back to using printf and a dumb terminal connected to a serial port to debug. Quite primitive, but at least it worked.
Rick, can you post a very small sample of compilable code that still shows this behavior?
Did you follow the machine code generated by the compiler to see if the variable assignment was optimized? Even at level 0 the Keil compiler does that if it can determine that an expression can be reduced (and that's GOOD). Local variables quite often don't have a life in RAM, but only in cpu registers.
You may also be experiencing a overlay reuse of the actual variable storage due to lifetime expiration. For example, the variable lifetime may expire at the middle of a C expression, so it will not have any meaningful value at the next C source line, because that address is actually allocated to another variable at that time. The local watch window does not make this clear, and you see a 'wrong' value.
Try to reference the variable in an unoptimizable way after the point that you want to watch, e.g., placing it at an expression in a bogus if(){} or while(){}clause after the intended watch point.
