In my project i am incrementing my array 1 and want to find the average of it.
But unfortunately my code is correct when i debugged but it gives an erroneous output when print the output.
I will put my code below can anybody say what is the problem in my function?
float Arr[81][11] = 0; float Ave[81] = 0;
This is my global declaration.
void Monitor_Slot4(void) { if(Slot_4 == 0) { Dev_Curr = fNewVREF_4 / Res; DevCurr_MinLimit = Dev_Curr - PassBand; DevCurr_MaxLimit = Dev_Curr + PassBand; //ROUTINE TO CHECK THE DEVICE VOLTAGE for(r=61;r<=80;r++) { fMonDevVol = 0.0; r = r + 12; fMonDevVol = fReadVoltage(r); r = r - 12; Arr[r][s] += 1; } if(s >= 10) { flt_Average(); s = 0; } return; }
The 's' is incrmented in another function where the control returns after executing the above function.
In the above routine when i watch the value of Arr[r][s] in debug mode the value is correct. But if i try to print the value it is showing a wrong value.
Is this due to memory problem.
void flt_Average(void) { unsigned int u_min,u_max; unsigned int u,v; average = 0.0; Ave[0] = 0.0; if(Slot_1 == 0) {u_min = 1; u_max = 20;} if(Slot_2 == 0) {u_min = 21; u_max = 40;} if(Slot_3 == 0) {u_min = 41; u_max = 60;} if(Slot_4 == 0) {u_min = 61; u_max = 80;} //consider slot_4 is 0 for(u=u_min;u<=u_max;u++) { for(v=1;v<=10;v++) { average += Arr[u][v]; } average /= 10; Ave[u] = average; if((u >= 61) && (u <= 80)) { SBUF= ' '; printf("\n aver is %f",Ave[u]); TI = 0; Delay(10000); SBUF=' '; printf("\n u is %u",u); TI = 0; Delay(10000); } average = 0.0; } return; }
In the above function if i try to print the Ave[u], the value is not '1' since in the previous function the value is always '1'.
I do not know where is the problem is?
Can anybody suggest me where the problem is ?
Ave[u][???] = average;
printf("\n aver is %f",Ave[u][???]);
[???] is the missing bit.
Actually i take 10 readings in the 2D array,
For example, In arr[1][10] has the ten readings.
After finding the average of these 10 values i store in a 1D array and store as Ave[1].
Sorry, when I read the post the first time, I didn't make the distinction between Arr and Ave.
Please help me i am clueless regarding this problem.
Bcos even when i tried to print the Ave[u] i got the output as shown below,
aver is 5427614000000000000000000000.0 u is 79 aver is -17761960000000000000000000000000000000.0 u is 80
I dont know y this happened.
Even when i tried to print the Arr[r][s] i didnt get the proper value.
Since this project is very urgent i need to finish it out ASAP.
Please suggest where the problem is located.
Are you sure that your array is initialized correctly; you are missing some curly brackets.
Thank you.
I had forgot to put the curley braces.
