fiq interrupt
hi,
i am using lpc2119 arm controller. i have tried to write a program for fiq interrupt using eint1 external interrup.
//program for fiq interrupt
#include <LPC21xx.H> // LPC21xx definitions
void fiqint(void);
int main(void)
IODIR1 =0X00FF0000;
PINSEL0 =0X20000000; //SELECT EINT1 IN PINCONNECT BLOCK
VICIntSelect=0x00008000; //ENABLE VIC CHANNEL AS FIQ
VICIntEnable=0x00008000; //ENABLE EINT1 INTERRUPT IN THE VIC
IOCLR1 =0X00FF0000;
while(1);
void fiqint(void) __fiq
IOSET1 =0X00FF0000;
above is the program that i have written. i am using keil compiler. when i build the program it is showing an error.
Build target 'Target 1'
assembling Startup.s...
compiling fiq intr.c...
fiq intr.c(13): error: #130: expected a "{"
Target not created
line 13 :void fiqint(void) __fiq
anybody please help me in clarrifying this problem. i am referring 'the insiders guide to the philips arm7 based controller'.hope you will be able correct the error in the code
thanking you
sanoop
