Regarding the thread "Flash file system problem" by Gennady Palitsky 2007-Apr-22, I came to the same point,where I have to create a Heap (8k) and copied retarget.c from C:\Keil\ARM\Boards\Keil\MCB2300\RL\FlashFS\SD_File to my application.
The problem I have is different: Stepping the following code, after "retv = finit( );" the program counter jumps back to the beginning of this function over and over.
/******************************************************************************** * Initializing MMC/SD Interface (SPI-MODE) * retv: 0 ok, 1 failed ********************************************************************************/ U32 mmc_init (void) { U32 retv; MMC_Disable; spi_init( ); MMC_Enable; retv = finit (); if (retv == 1) { printf ("\nSD/MMC Init Failed"); } else { printf ("\nSD/MMC Card is Unformatted"); strcpy ((char*)str, "SWMZ\r\n"); cmd_format ((char*)str); retv = finit (); } return(retv); }
