External flash programming
I'm programming an XC161 with internal flash memory at 0xC00000..0xC1FFFF and external flash at 0x400000..0xBFFFF (only 0xBB0000..0xBFFFFF 256K is used for program/data - the rest is for a flash file system).
Currently when the code is linked, it starts linking to the external memory at 0xBB0000. I presume because the address of the external memory is lower than the internal memory.
I want the code/data to be loaded into the internal flash memory where possible but if/when the code/data can't fit into the 128K internal flash I want it to be stored in the external flash.
Is there simple* way to specify that all code/data should be linked to the internal flash memory unless it can't fit, which case it should go into the external flash memory.
* By simple, I mean without hardcoding addresses (in the linker) of where to link each source module.
Regards
Paul
  • I'm not sure if this issue can be solved as simple as requested. We had a similar configuration and used the following approach:
    - We seperated our code into "frequently called" and "less frequently called".
    - The former went to the internal flash and
    - for the latter we introduced a code class, e.g. named ECODE. In the corresponding sources (we used a memory model with far code) we put
    #pragma RENAMECLASS(FCODE=ECODE)
    - For the locator, we just specified
    ECODE (0x400000-0x44FFFF)
    So there is only one address hardcoded.
  • Thanks for the speedy reply Thomas.
    That's as good a solution as I was hoping for. I think it will suit our purpose very well :)
    Regards
    Paul
