Hi....I am writing code for STR710FZ2 using Keil compiler.when i checked the sizeof a structure which i defined i got the size as 12 eventhough the actual size is 10.Since arm is 32 bit i can only defines structure whose size is a multiply of 4...can anybody tell me a way to overcome this problem....
A large number of processors require that integers larger than one byte must be aligned corresponding to their size, i.e. a 16-bit integer mut be aligned on an even address, and a 32-bit integer must be aligned in an address evenly dividable by 4.
If you have a struct containing one 32-bit integer and one 16-bit integer, the used size may be 4+2 = 6 bytes. However, to be able to create arrays of such a struct, the struct must be padded to 8 bytes or the 32-bit integer in the following struct would not be correctly aligned, i.e.:
struct { u32 a; u16 b; } my_array[4];
will result in the following:
offset value 0 my_array[0].a 4 my_array[0].b 6 2-byte padding 8 my_array[1].a 12 my_array[1].b 14 2-byte padding 16 my_array[2].a ...
In your case, you have a struct that contains at least one 32-bit integer. Therefore, the struct will have a size that is 4*n byte large.
To overcome the problem use the __packed attribute. More info: http://www.keil.com/support/man/docs/armcc/armcc_cjajddhb.htm
You're basing your expectations on incorrect assumptions. The actual size of that struct is exactly what the compiler says it is.
By understanding that the problem is not what you think it is. The problem is not that the compiler isn't giving you the struct size and alignment you expect. The problem is that you're trying to use a C struct for something it's not meant to be used for. While extensions like __packed may appear to solve the issue, they really just muddy the water some more.
C structs are for use inside your program, not for interfacing with the outside world. If you have to match externally defined data formats, use different methods. E..g write single bytes suitably isolated from C internal variables.
