carry bit
as i am doing in assembly language
 setb c
       clr  c
it work's fine but when i tried it in c
 c  = sd;
      sd = c;
the sd may be the high or low it gives error related to declaration of c, i solved it by defining
 sbit C = PSW^7;
i want to know the reasion why it need the seprate declaration.it not required in assembly so why in c please help me to solve this problem
  • i want to know the reasion why it need the seprate declaration.
    The carry bit should be declared as CY in your <[processor type].h> include file.
    Because C, all by itself, does not care about the hardware. As far C is concerned, it is entirely irrelevant if your processor even has a carry bit.
    Assembler, on the other hand, is very machine-specific.
    On a side note, it is generally considered to be a bad idea to mess around with the carry flag in C.
  • thank's for the help, i went to the c with the same idea as the assembly and did not refer the reg file.thank's again
