I have successfully used the uVision3 slog command to divert printf() data to a text file using an Infineon C164 processor connected via a serial link. However I'm unsure how this works with the ARM processor where downloads and control use the JTAG interface via a Keil ULINK module.
Any help would be appreciated.
Don
SLOG does not work there. You may use a slightly different technique for outputs. Take a look to
C:\Keil\ARM\RV30\Boards\Keil\MCB2100\DebugIO
Hi Reinhard,
Thanks for your help, I will check the MCB2100 example programs. Perhaps I have missed something but the fact that slog is not supported here does not seem to be very well documented.
Regards,
