I tried setting up the MCBSTR9 board directly to laptop using a cross-over cable. I loaded a DHCP server on the laptop that someone recommended, and ran a network analyzer program to watch what happens.
I set the ini file for DHCP server as instructed.
The initial packets from the MCBSTR9 are all DOD/UDP type packets, and I never see an ARP packet - so the DHCP server never responds with the IP address from the ini file. I force the laptop IP address as suggested in an SMSC CP220x demo board user guide (in Network Settings, etc)
I see in the example code the default IP address 192.168.0.100, but of course when it sends out the DOD/UDP packets (broadcast) the IP address shows up as 0.0.0.0. It would be nice if there was alternative build of the HTTP DEMO that just used a fixed IP address so that we can demo the board without involving the company network - just a crossover.
David,
where are you located? We can provide you with an example, but I would like that you are working with a local reprensentative on that.
Reinhard
Dear David Frazer,
i came to know that u r working on MCBSTR9 Evaluation Board. here we are also working on the same board. actually we are facing some problems with this board.
only blinky program is running on this board.the path for this program is :C:arm/rv30/boards/keil/blinky we are unable to run the example programs of ST. the path for the program is C:arm/rv30/boards/st/blinky
could u please help us regarding this?
thanks in advance regards raj.
