Keil MCB2140 board: Alternate power supply method
Hi
I am currently using the MCB2140 Board as a USB-powered device (the default). However I want to power it using some alternate method. The only documentation I found was "Remove the 0 Ohm resistor (R37) to use the VIN connector P14 as an external power supply connection." on the user manual of mcb2140. It is not very clear how to go about doing this - could anyone pl explain.
Regards
Ramesh Kumar
0
