I want to pass a 2-D array from one function to another function. I wrote the program but sometimes i get wrong values.
float Arr[81][10];
void Monitor_Slot1(void) { if(Slot_1 == 0) { Dev_Curr = fNewVREF_1 / Res; DevCurr_MinLimit = Dev_Curr - PassBand; DevCurr_MaxLimit = Dev_Curr + PassBand; //ROUTINE TO CHECK THE DEVICE VOLTAGE for(r=1;r<=20;r++) { fMonDevVol = 0.0; fMonDevVol = fReadVoltage(r); Arr[r][s] = fMonDevVol; if(s > 9) { s = 0; flt_Average(Arr); } Delay(100); } } }
void flt_Average(float arr[][10]) { unsigned int u_min,u_max; unsigned int u,v; average = 0.0; Ave[0] = 0.0; if(Slot_1 == 0) {u_min = 1; u_max = 20;} if(Slot_2 == 0) {u_min = 21; u_max = 40;} if(Slot_3 == 0) {u_min = 41; u_max = 60;} if(Slot_4 == 0) {u_min = 61; u_max = 80;} for(u=u_min;u<=u_max;u++) { for(v=0;v<10;v++) { average += arr[u][v]; } average /= 10; Ave[u] = average; if((u >= 61) && (u <= 80)) { SBUF= ' '; printf("\n aver is %1.2f",Ave[u]); TI = 0; Delay(1000); SBUF=' '; printf("\n u is %d",u); TI = 0; Delay(1000); } average = 0.0; DevVol_Check(Ave,u); } return; }
In the function Monitor_Slot1(void) i am taking 10 sets of reading for each device. The total devices are 80.
After the 10 readings are taken i calculate the average of the readings. That is done in the second function flt_average().
For example let us assume that device number i.e 'i' is 5 and 10.
When i check the reading of this number it is correct.
But after passing to the flt_average function the average is showing either '0' or garbage number.
I dont know whether the method i followed for storing the number is correct and alos the way i passed an 2-D array is correct or not.
If this method is worng is there any other better method to do it?
Please suggest me.
