I have declared around 15 variables as,
code constant float var1 = 1.0; code constant float var2 = 3.5; . . . .
when i see my file.m51 the file is showing these variables are located in xdata.
i am using 8031 with external EPROM memory of 64kb and external RAM of 8KB.
i do not know what is happening?
can anybody tell what might be cause for the problem?
Well, when I compile your example, I get the following:
line level source 1 code constant float var1 = 1.0; *** ERROR C129 IN LINE 1 OF MAIN.C: missing ';' before 'float' 2 code constant float var2 = 3.5; C51 COMPILATION COMPLETE. 0 WARNING(S), 1 ERROR(S)
The word "constant" is not a C keyword. Maybe you mean "const".
Jon
Ya i am sorry.
Actually i had declared my variable like this,
code const float var1 = 1.2; code const float var2 = 13.6;
Like that around 15 variables are declared.
After compilation , i can see the xdata , code size but y the compiler doesnt show the const size?
In the .Map file also i see that after declaring the const var, the var where it is stored is showing as xdata not as code.
do i need any setting?
