Load "C:\\Keil\\C51\\Examples\\Chipcon\\RF\\halRFtest\\halRFtest_433" *** error 65: access violation at I:0x80 : no 'write' permission
616: INT_SETFLAG(INUM_TIMER0,INT_CLR); C:0x13BF C28D CLR TF0(0x88.5)
Memory Map 001: I:0x00 - I:0x7F read write 002: C:0x0000 - C:0xFFFF exec read 003: X:0x000000 - X:0x00FFFF read write
error caused by Timer0 ISR trying to clear the timer overflow flag at TCON^5, when I try to reset Memory to what the User's Guide calls for.
0x000000 - 0x00FFFF read/write this should be IDATA that overlaps the SFR's right? 0x010000 - 0x01FFFF read/write this is XDATA 0xFF0000 - 0xFFFFFF exec read this is CODE
I have try'ed to enter the default map for small memory model using DeBug > Memory Map but keep getting error:invalid address range given.
what could have caused the change in the memory map and how should i change it back, please help
Calvin
I'm reasonably sure no User's Guide applicable to Keil C51 calls for that memory map. You've mixed up memory spaces (code,data,idata,xdata) and their internal encoding for generic pointers. The debugger uses prefixes to indicate memory spaces. And no '51 on this planet has a DATA space going up all the way to 0xffff.
You've also misinterpreted the error message. It is not about the machine instruction you've shown. It's about an instruction using indirect access to address 0x80 --- probably the one directly before the one you've shown. The reason for that is perfectly clear from the memory map as shown: you configured the tools to believe your chip has only 128 bytes of internal RAM --- a property that's pretty much nonexistant in today's '51 controllers.
Thanks for the response, I have modified the halRFtest_full example program to function with my prototype circuit the error 65 happens in a ISR used to flash LEDs in the background while polling for user input this code worked fine untill I expanded my code, have I voilated some restriction?
void TIMER0_ISR() interrupt INUM_TIMER0 { int i; INT_SETFLAG(INUM_TIMER0,INT_CLR); ISR_TIMER0_ADJUST(tCounter); for(i=0;i<30000;i=i+1) { } P0_0=~P0_0; P2_4=~P2_4; }// End Timer0 ISR
compiling halRFtest.c... HALRFTEST.C(161): warning C260: '=': pointer truncation linking... Program Size: data=99.2 xdata=186 const=39 code=5296 creating hex file from "halRFtest_433"... "halRFtest_433" - 0 Error(s), 1 Warning(s).
Why would you add a long loop in an interrupt service routine? They should _always_ be optimized for speed, since that makes sure that: - it has finished before the next interrupt - you can service other interrupts without needing to nest interrupts - you have time left for a main loop - reduce lag when processing interrupts
I'm sure that other people here can append a lot of further reasons.
Ok I see your point, what would be a better way to handle a polling loop for 'Button Push' with no other interrupts enabled, also this polling loop happens only on the initial setup.
are you, in effect, saying that after power up somebody must push a start button - nothing else?.
Simple. Do your polling outside the ISR. The timer ISR should do nothing but count up time. The polling loop can then go on to check the state of that button, and use the ISR's running time counter to determine how long the button was pressed (for debouncing purposes).
why bother,
if the issue is to see the button pressed at start (the OP mention nothing else) and the button has no other purpose, there is no reason, whatsoevet to debounce it.
The OP need clarify NOT his code, BUT the purpose of it.
Eric, actually there are 2 buttons being polled one cycles options the second selects the chosen option, the timer0 interrupt is started before entering the polling loop and select ends timer0 and breaks; from input loop.
What does OP stand for?????
what about my problem------------------------- error 65:access violation at I:0x80 ; no"write" permission
this should be the SFR space 0x80 - 0x7F ? as defined by the SMALL memory model right ?
the (or is it just 'my') standard means of debouncing buttons is as follows
set a timer to interrupt at (maximum bounce time + fudge)
In the ISR read the buttons and only report the change (to a global variable) if the button has read the same two consqutive times. Then, in the main act upon that global variable.
error 65:access violation at I:0x80 ; no"write" permission two possibilities a) you have chosen parametres that specify a derivative with no idata (e.g. a traditional 8051) b) you are trying to (re)set SFRs or SFR bits with syntax not acceptable to Keil. e.g. a SFR must be defined as 'SFR' not 'data'
Original Poster i.e. whoever presented the problem.
I:0x80 [...]this should be the SFR space 0x80 - 0x7F ? as defined by the SMALL memory model right ?
No. The "I:" prefix means it's IDATA, not SFRs. What this means is that your debugger memory map is set up for a real 128-byte RAM 8051 device, but your program was built to run on a bigger (256-byte) variant. One of the two is wrong. You figure out which. Pay special attention to your startup code
