I'm using the Keil ARM Evalution Software (uV3 v3.51)
When I try to compile or assemble the LPC2148 USB HID Example I get the following errors:
--- Error: can't execute 'C:\Keil\ARM\BIN\AA' --- Error: can't execute 'C:\Keil\ARM\BIN\CA'
What can I do? Is this a configuration error?
Solved the problem. Require ARM patch.
I have exactly the same problem.
What is the ARM patch and where did you get it from?
Thanks Vishal
http://www.keil.com/support/docs/3267.htm
But you can use the GNU compiler, no limitations and free.
Hey thanks! The patch indeed worked. It was not at all easy to guess such a patch would be needed in addition to the default download.
