I'm using Phytec KC161 eval board with mVision3. Can someone tell how to work with banked memory in keil? Thanks.
How do you define banked memory?
The C161 can address up to 16 Mbyte of memory directly is this not enough for your system/application?
At my eval board I have 64K external RAM and 256k external FLASH. So, can I make applications without banked memory? But I have problems at simple array initializations. When the device is free running, it doesn't initialize arrays, why?
My eval board is Phytec KC-161.
