I'm debugging a firmware update problem and notice that uVison2 and 3 do not refresh the dissasembly or code memory views.
In other words, my app writes the new code into flash, but Uvision still thinks the old code is there.
Is there a way to get the latest version of uVision to refresh it's view of flash?
Thanks,
Mark
"I need to know what's actually in flash memory, not what I think is in flash memory or what Uvision thinks is in flash memory."
What does a flash have in it at the time of manufacture?
Is that known to The AlMighty CReator,
imean the manufacturer..
wonder what this talk is for... once it is been "accepted" to interface for a particular purpose, the flash will be connected to the same, to load the intended program, is it not so,
< b>Flash also needs to know what is in 8051.
Cache, Primary memory, etc are in PC, 8051, flash has only one memory, in it, part for code : once set is set, part for data: for day to day purpose
after much consideration, debugging, checking out the program, it is committed to the purpose, its done only once but the right one, so that there is no need for repenting later on, coz everybody agrees memories are delicate.
"It takes considerable time to make sure the everything is set up properly in the SiLab ide to match the settings of Uvision in order to create the exact image"
As a workaround, can you not just load the image built by uVision into the SiLabs IDE for this?
"I don't want to use some crappy IDE, when the best tool just needs to refresh it's (sic) view of flash."
Have you contacted Keil support about this?
Do you simply need to know what's there, as Christoph Franck is saying, or do you also want to continue symbolic debugging of the newly-loaded image?
For the former, doesn't the memory display window read directly from the target?
For the latter, how does the SiLabs IDE know where to get its symbol information to match the new image?
What interface are you using between uVision and your target?
part for code : once set is set"
You've never heard of In-Application Programming (IAP), and firmware updates, then?
"everybody agrees memories are delicate"
Do they??
Whats meant by symbolic debugging of the newly-loaded image,
What s that?
memories are used with careful consideration, is it not?
Thats Right!
What did you want to say.?
"I don't want to use some crappy IDE, when the best tool just needs to refresh it's (sic) view of flash." whats sic in that,
Have you contacted Keil support about this? Keil being BUSY, has time for BASIC queries..? I wonder,
"I think it would get confusing, though, if the debugger was trying to use the symbols for image 'A' whilst looking at image 'B'...!! :-0"
Does Debugger do mistakes, i mean, be playful enough to off-spin ?
Andy, I don't need symbolic debugging. I just need to single step at the assembly level for a little while through the newly written code. What I see now when I single step through the new code is the disassembled old code. A memory view of the new area also shows the old data. I am using the SiLab usb jtag debugger.
ok, understood,
" where do u get the new code"
"sometimes , just sometimes, dont u ever feel like a zombie working in Embeddede systems..."
The new code comes in from the serial port.
evidently YOu did
Talking of cache, there are the MIsses, cache MISS, hit MMISS, all MISS., evidently missing all along,
