While trying to interface flash SST25VF512 with AT80c51, i find difficulty in Byte program mode of writing to flash.
This is the code i used, could somebody who has worked on this please help me out,
void main(void){ ce = 1; SCK = 0; TMOD = 0x20; TH1 = -3; // 9600 baud SCON = 0x50; TR1 = 1; TI = 1; addr = 0x00000012; Rd_ID = Read_ID(); Byte_Program(addr); void Byte_Program(unsigned long addr){ ce = 0; E_WRSR(); WREN(); Send_Byte(0x02); // Byte Program CMD Send_Byte(((addr & 0xFFFFFF) >> 16)); // sending 3 address bytes Send_Byte(((addr & 0xFFFF) >> 8)); Send_Byte(addr & 0xFF); Send_Byte(0x10); //send data SR_byte = Read_Status_Register(); while((SR_byte &0x01) != 0x00){ SR_byte = Read_Status_Register(); } ce = 1; } void E_WRSR(){ ce = 0; Send_Byte(0x50); // enable Status Reg ce = 1; ce = 0; Send_Byte(0x01); // select write to status register Send_Byte(0x00); // mode 0, ce = 1; } void WREN(){ ce = 0; Send_Byte(0x06);// to Write enable ce = 1; } unsigned char Get_Byte(){ unsigned char i=0, in=0, temp=0; for(i=0;i<8;i++){ in = (in << 1); temp = SO; SCK = 1; if (temp == 1){ in = in | 0x01; } SCK = 0; } return in; } void Send_Byte(unsigned char b_out){ for(i=0;i<8;i++){ if((b_out & 0x80) == 0x80) si = 1; else si = 0; SCK = 1; b_out = (b_out << 1); SCK = 0; } }
Thanks in advance,
Thanks Neil, How do you say the write function code should be, After writing the byte, the status reg reads 02, ie finished writing. Then should there be some change in the read function code? Where do you think is the mistake,
"However, the status register in these types of flash is non-volatile, implemented with the same flash technology as the rest of the chip." How is that only status reg is non volatile? I could nt find this info in datasheet. Where do we get such finer details?
"How do you say the write function code should be"
Never mind what I say - what does the Manufacturer say?
Don't SST provide example code for this?
If that had worked, would not have asked you
Had followed the manufacturer's code supposedly there are fine changes to be done thought you got an eye for detail SST does provide code, though there are things to be added to it like Enable operation etc..
