Retrieving data from array.
I am trying to retrieve data from an array "Buf" to register but am unable to do so.
Below is my code:
long T_msec,Div= 360000;
int T_hours;
char Buf[3];
while(1)
{ check_digit();
T_msec = oncount;
T_hours = (int)(T_msec/Div);
sprintf(Buf,"%ud",(int)(T_msec/Div));
hour0digit = Buf[0];
hour1digit = Buf[1];
hour2digit = Buf[2];
// hour3digit = Buf[3];
p07 = 0;
Please help me..
Aniket
  • not
    sprintf(Buf,"%u",(int)(T_msec/Div));
    is enough.
    what is the type of hour0digit,1digit,2digit?
    what is your problem?
    what are you getting in the hour0digit,1digit,2digit after the 3 assignment statements?
  • Hi,
    I have a 4byte count which i have to reduce and display it on a 7 segment display in three digits hour0digit,hour1digit & hour2digit respectively. Below i have given an example count which is in miliseconds and i have to convert it to hours.
    Ex: 252000000ul; //700 hours;
    Thanks and regards,
    Aniket
  • hi,
    char Buf[3];
    You are in trouble here -- you should either make array enough long or limit number of printed chars by %.number modifier for sprintf()
    For example, "700" requires 4 bytes (note null-terminator at the end of string).
    Then look at assembler code generated by compiler. It may be that optimizer ejects some lines then read more about nonvolatile keyword.
    Regards,
    Oleg
