Hi there!
Can anybody help me with my problem?
If I calculate checksum from 0x0 to 0x3000 - it is OK. But if I want to calculate 0x0 to 0xFA00 range - checksum is different every microcontroller reboot. I wrote programm in flash and start MK from there, not as bootstrap. Checksum shows at LCD.
Some data: Shecksum calculation procedure:
unsigned char CheckChecksum (void) { unsigned char *start_addr; unsigned int len, step, i = 0; unsigned char checksum = 0; start_addr = 0x000; len = 0xFA00;//0x3000; step = len / 22; ShowCalcCheckSum( len ); // Out some info on LCD for (i = 0; len > 0; len--, start_addr++, i++) { checksum += *start_addr; if ( i == step ) { WriteByte(0x0,1); i = 0; } } FlashChecksum = checksum; return checksum; }
.BAT file for insert correct checksum in hex-file
c:\keil\uv3\hex2bin %1.H86 c:\keil\uv3\check8 %1.bin /s0x00 /e0xF9FE /p0xF9FF /v0x80 c:\keil\uv3\bin2hex %1.bin %1a.H86
Calculating a checksum for internal MEMORY doesnt really make sense, does it? ;-)
Hi, Salvatore!
Why do you think that I have INTERNAL memory at 0x0 - 0x1FFF but not EXTERNAL memory? Are you really know pins EBC1 and EBC0 on my MK? I do not know, but I will ask my hardware engeneer later.
And why
in that case?
OK - I'll try calculate checksum from 0x2000 to 0xFA00. Is it really what you mean?
Hi again
Am I wrong or this means that I have no internal ROM (0x1E78 < 0x1FFF)?
25: unsigned char CheckChecksum (void) 00001E72 ECFF PUSH R15 00001E74 06F0F6FF ADD R0,#0xFFF6 26: { 27: unsigned char *start_addr; 28: unsigned int len, step, i = 0; 00001E78 E004 MOV R4,#0x00 00001E7A C4400600 MOV [R0+#0x0006],R4 29: unsigned char checksum = 0;
I dont know, show me your BUSCON and ADRSEL registers.
You want this startup.a66 file?
;------------------------------------------------------------------------------ ; ; Definitions for SYSCON Register (System Configuration): ; ------------------------------------------------------- ; ; MCTC: Memory Cycle Time (SYSCON.0 .. SYSCON.3): ; Note: if RDYEN == 1 a maximum number of 7 waitstates can be selected _MCTC EQU 1 ; Memory wait states is 1 (MCTC = 0EH). ; ; (Reset Value = 15 additional state times) ; ; RWDC: Read/Write Signal Delay (SYSCON.4): _RWDC EQU 0 ; 0 = Delay Time 0.5 States (Reset Value) ; ; 1 = No Delay Time 0 States ; ; MTTC: Memory Tri-state Time (SYSCON.5): _MTTC EQU 1 ; 0 = Delay Time 0.5 States (Reset Value) ; ; 1 = No Delay Time 0 States ; ; BTYP_ENABLE: Enable External Bus Configuration Control Bits ; --- Set BTYP_ENABLE = 1 to allow modification of BTYP and BUSACT field ; in the SYSCON register. $SET (BTYP_ENABLE = 0) ; ; BTYP: External Bus Configuration Control (SYSCON.7 .. SYSCON.6): ; Note: These bits are only valid if _BUSACT == 1. _BTYP EQU 0 ; 0 = 8 Bit Non Multiplexed ; ; 1 = 8 Bit Multiplexed ; ; 2 = 16 Bit Multiplexed ; ; 3 = 16 Bit Non Multiplexed ; ; CLKEN: System Clock Output Enable bit (SYSCON.8): _CLKEN EQU 0 ; 0 = disabled (Reset Value) ; ; 1 = enabled ; ; BYTDIS: Byte High Enable pin control bit (SYSCON.9): _BYTDIS EQU 0 ; 0 = enabled (Reset Value) ; ; 1 = disabled ; ; BUSACT: Bus Active Control Bit (SYSCON.10): _BUSACT EQU 1 ; 0 = disabled ; ; 1 = enabled (Reset Value) ; ; SGTDIS: Segmentation Disable control bit (SYSCON.11): $IF TINY _SGTDIS EQU 1 ; disable segmented mode for TINY model $ELSE _SGTDIS EQU 0 ; enable segmented mode (Reset Value) $ENDIF ; ; RDYEN: READY# Input Enable control bit (SYSCON.12): _RDYEN EQU 0 ; 0 = disabled (Reset Value) ; ; 1 = enabled ; ; RDY_AS: Synchronous / Asynchronous READY# Input (SYSCON.3): ; Note: This bit is only valid if _RDYEN == 1. _RDY_AS EQU 0 ; 0 = synchronous READY# input ; ; 1 = asynchronous READY# input ; ; STKSZ: Maximum System Stack Size selection (SYSCON.13 .. SYSCON.14) ; Defines the system stack space which is used by CALL/RET and PUSH/POP ; instructions. The system stack space must be adjusted according the ; actual requirements of the application. $SET (STK_SIZE = 0) ; System stack sizes: ; 0 = 256 words (Reset Value) ; 1 = 128 words ; 2 = 64 words ; 3 = 32 words ; 4 = not implemented ; 5 = not implemented ; 6 = not implemented ; 7 = size adjustable (up to 512 bytes in on-chip RAM, start at 0FA00H) ; If you have selected 7 for STK_SIZE, you can set the actual system stack size ; with the following SSTSZ statement. SSTSZ EQU 200H ; set System Stack Size to 200H Bytes ; ; USTSZ: User Stack Size Definition ; Defines the user stack space available for automatics. This stack space is ; accessed by R0. The user stack space must be adjusted according the actual ; requirements of the application. USTSZ EQU 1000H ; set User Stack Size to 1000H Bytes. ; ; EXT_RAM: External RAM Write Access Enable (P3.13 = WR-Pin) ; --- Remove following statement if no external RAM is used $SET (EXT_RAM) ; ; WATCHDOG: Disable Hardware Watchdog ; --- Set WATCHDOG = 1 to enable the Hardware watchdog $SET (WATCHDOG = 0) ; ; ; CLR_MEMORY: Disable Memory Zero Initialization of RAM area ; --- Set CLR_MEMORY = 0 to disable memory zero initilization $SET (CLR_MEMORY = 1) ; ; INIT_VARS: Disable Variable Initilization ; --- Set INIT_VARS = 0 to disable variable initilization $SET (INIT_VARS = 1) ; ; DPPUSE: Re-assign DPP registers ; --- Set DPPUSE = 0 to reduce the code size of the startup code, if you ; are not using the L166 DPPUSE directive. $SET (DPPUSE = 1) ; ;------------------------------------------------------------------------------ ; ; BUSCON1/ADDRSEL1 Initialization ; =============================== ; ; ; BUSCON1/ADDRSEL1 ; --- Set BUSCON1 = 1 to initialize the BUSCON1/ADDRSEL1 registers ; CHANGED from 0 $SET (BUSCON1 = 1) ; ; Define the start address and the address range. ; These values are used to set the ADDRSEL1 register %DEFINE (ADDRESS1) (20000H) ; Set CS1# Start Address (default 20000H) %DEFINE (RANGE1) (128K) ; Set CS1# Range (default 128K) ; ; MCTC1: Memory Cycle Time (BUSCON1.0 .. BUSCON1.3): ; Note: if RDYEN1 == 1 a maximum number of 7 waitstates can be selected _MCTC1 EQU 1 ; Memory wait states is 1 (MCTC1 field = 0EH). ; ; RWDC1: Read/Write Signal Delay (BUSCON1.4): _RWDC1 EQU 0 ; 0 = Delay Time 0.5 States ; ; 1 = No Delay Time 0 States ; ; MTTC1: Memory Tri-state Time (BUSCON1.5): _MTTC1 EQU 1 ; 0 = Delay Time 0.5 States ; ; 1 = No Delay Time 0 States ; ; BTYP1: External Bus Configuration Control (BUSCON1.6 .. BUSCON1.7): _BTYP1 EQU 0 ; 0 = 8 Bit Non Multiplexed ; ; 1 = 8 Bit Multiplexed ; ; 2 = 16 Bit Multiplexed ; ; 3 = 16 Bit Non Multiplexed ; ; ALECTL1: ALE Lengthening Control Bit (BUSCON1.9): _ALECTL1 EQU 0 ; see data sheet for description ; ; BUSACT1: Bus Active Control Bit (BUSCON1.10): _BUSACT1 EQU 1 ; = 0 external (ADDRSEL1) bus disabled ; = 1 external (ADDRSEL1) bus enabled ; ; RDYEN1: READY# Input Enable control bit (BUSCON1.12): _RDYEN1 EQU 0 ; 0 = READY# function disabled ; ; 1 = READY# function enabled ; ;------------------------------------------------------------------------------
