Bar graph
Hi
In my project iam measuring the leak rate.
The range of leak rate is 1.0E-11 to 1.0E-02.Up now I measured leak rate and displayed
On the 7 segment display with 0.1 resolution. Here I used look up table method I taken hole Range values In the table and iam displaying the value for corresponding voltage .
I stored values in the farm Of (1011 =1.0E-11) here "." ,"E","-" are constants.
Now I want display the leak rate on BAR graph display.
For 20 digits I have to take one led.
The fallowing values I have to show on bar graph
1E-11, 3E-11, 5E-11, 7E-11, 9E-11, 1E-10,
3E-10, 5E-10…………………………………………2E-02
ex:
1E-11 = one led should glow
3E-11 = 2 leds should glow
5E-11 = 3 leds should glow
How to convert table values in to bar graph display.
Regards
  • Thank for reply
    Iam using 50 Ifs in my program.
    IF value > threshold_1 THEN led1: = on;
    IF value > threshold_2 THEN led2: = on;
    IF value > threshold_1 THEN led3: = on;
    IF value > threshold_2 THEN led4: = on;
    IF value > threshold_1 THEN led5: = on;
    IF value > threshold_2 THEN led6: = on;
    IF value > threshold_1 THEN led49 := on;
    IF value > threshold_2 THEN led50 := on;
    EX:
    0000 0001 – led1 glow
    0000 0011 – led2 glow
    0000 0111 – led3 glow
    0000 1111 – led4 glow
    0001 1111 – led5 glow
    0011 1111 – led6 glow
    0111 1111 – led7 glow
    1111 11111 – led8 glow
    How to send control word on to the PORT 6 times?
    How to display on the leds means what type of hardware I have to use?
    Regards
    Sri
  • "...what type of hardware I have to use?"
    So this is now off-topic - no longer a question about Keil tools.
    But I thought you'd already decided:
    "iam using HDSP4830 bar graph displays"
  • Avago Technologies; formerly Agilent; previously Hewlett-Packard (HP).
    As always, when using any electronic device, your first port of call should be the Support section of the manufacturer's website. There you should search for the Data sheet, Application Notes, and other supporting materials.
    Try this:
    http://www.avagotech.com/products/product-detail.jsp?navId=HDSP-4830
  • "EX:
    1111 11111 – led8 glow"
    Do you mean:
    0000 0001 – LED  1 glows
    0000 0011 – LEDs 1,2 glow
    0000 0111 – LEDs 1,2,3 glow
    0000 1111 – LEDs 1,2,3,4 glow
    0001 1111 – LEDs 1,2,3,4,5 glow
    0011 1111 – LEDs 1,2,3,4,5,6 glow
    0111 1111 – LEDs 1,2,3,4,5,6,7 glow
    1111 1111 – LEDs 1,2,3,4,5,6,7,8 glow
    or:
    0000 0010 – LED 2 glows
    0000 0100 – LED 3 glows
    0000 1000 – LED 4 glows
    0001 0000 – LED 5 glows
    0010 0000 – LED 6 glows
    0100 0000 – LED 7 glows
    1000 0000 – LEd 8 glows
