Hi In my project iam measuring the leak rate. The range of leak rate is 1.0E-11 to 1.0E-02.Up now I measured leak rate and displayed On the 7 segment display with 0.1 resolution. Here I used look up table method I taken hole Range values In the table and iam displaying the value for corresponding voltage . I stored values in the farm Of (1011 =1.0E-11) here "." ,"E","-" are constants. Now I want display the leak rate on BAR graph display. For 20 digits I have to take one led. The fallowing values I have to show on bar graph 1E-11, 3E-11, 5E-11, 7E-11, 9E-11, 1E-10, 3E-10, 5E-10…………………………………………2E-02 ex: 1E-11 = one led should glow 3E-11 = 2 leds should glow 5E-11 = 3 leds should glow : : : How to convert table values in to bar graph display. Thanks Regards
a series of 20 ifs?
does your bar display have 9*(11-2+1) = 90 bars?
oops, sorry.. it would be 50 :D
Thank for reply iam using HDSP4830 bar graph displays each bar graph have 10 leds. Regards sri
So how many actual bars do you have? (my initial comment about 20 was a misreading of your original post - sorry).
Thanks for reply Here iam using 5 bar graph displays. It has 50 bars. The whole range 1.0E-11 to 1.0E-02 I have to show on 50 bars. E-12 - 1 bars glow 2E-12 - 2 bars glow 4E-12 - 3 bars glow 6E-12 - 4 bars glow 8E-12 - 5 bars glow E-11 - 6 bars glow 2E-11 - 7 bars glow 4E-11 - 8 bars glow 6E-11 - 9 bars glow 8E-11 - 10 bars glow E-10 - 11 bars glow 4E-10 - 12 bars glow : : E-02 - 50 bars glow Regards Sri
You could have a 'const' array with the 50 threshold values; then loop through to find how many LEDs should be on or off... Or a series of 50 ifs...
Can give view on threshold values and series of 50 ifs. E-12 - 1 bars glow means we have send 0x8000 0000 0000 00 value. E-02 - 50 bars glow means we have send 0xFFFF FFFF FFFF 11 value.
The Threshold values are the values above which each LED turns ON (or OFF, depending which way you look at it). You have basically given this information in your post already!
IF value > threshold_1 THEN led1 := on; IF value > threshold_2 THEN led2 := on; IF value > threshold_3 THEN led3 := on; etc etc
Thanks for reply If we write 50 IF LOOPS means program become large and complex. In another method what elements we have to store in ARRAY. can give any logic for this problam. Regards sri
If we write 50 IF LOOPS means program become large and complex. 1) there is no such thing as an "IF LOOPS" 2) what is 'large and complex' about 50 lines of code? In another method what elements we have to store in ARRAY. you can di like this (based on the 50 if) with 2 tables IF value > threshold[index] THEN led[index] := on; Erik
#define NumLeds 12 Value Threshold[NumLeds] = { // for each LED, list the value at which // the LED should turn on }; currentValue = GetCurrentValue(); // go through all LEDs, lowest to highest, // and turn on all those LEDs for which the // current value is greater than its threshold for (led = 0; led < NumLeds; ++led) { if (currentValue >= Threshold[led]) { // current value is at least high enough // to activate this LED SetLed (led, LedOn); } else { // turn off LEDs // current value no longer high enough // to activate this LED SetLed (led, LedOff) } }
Thanks for reply Here I wane glow 50 leds means I have to send 50 ones on to the port. My doubt is how to store the 50 ones in the array? Here I well use 7 latches (8 bit data * 7 latches =48 bits). So I well send only 8 bits on to the port. For 48 bits I want send 7 times on to the PORT. Ex: /* First 8 bits */ C1=0;/* latch disable*/ P1=8 bit data; C1=1;/* latch enable*/ /*Second 8 bits */ C1=0;/* latch disable*/ P1=8 bit data; C1=1;/* latch enable*/ /* Third 8 bits */ C1=0;/* latch disable*/ P1=8 bit data; C1=1;/* latch enable*/ : : /* Seven 8 bits */ C1=0;/* latch disable*/ P1=8 bit data; C1=1;/* latch enable*/ How to divide the 48-bit number in to seven 8-bit numbers? Regards Sri
"If we write 50 IF LOOPS means program become large and complex." As already noted, there is no such thing as an "IF LOOP" 50 'if' statements doesn't even fill a single page of source code - that's not really a lot. And it certainly isn't complex: it is very simple indeed - just a lot of tedious repetition. And 'if' statements should compile to something fairly simple - so the generated code should not be that large or complex either. The alternative is to store the comparison values in an array, a use a loop to check through each value for each LED see Drew's example. This is actually more "complex" - since you still need to do exactly the same comparisons, but you have added the "overhead" of the array and the loop! The loop-based code may or may not be smaller, due to the space occupied by the array... Whichever actually turns out to be smaller, the difference is likely to be not terribly significant. Why don't you try both and post back your conclusions?
"How to divide the 48-bit number in to seven 8-bit numbers?" Why 48 bits? If you have 50 LEDs, you need 50 bits! Keil C51 doesn't have any data type larger than 32 bits anyhow, so you can't do it directly. Easiest way is probably to have a 7-byte array: array[0] holds bits 0-7; array[1] holds bits 8-15; : : array[6] holds bits 48-55 (note you have some spare bits here). Hint: Look up the Modulus operator, '%' (percentage sign), in your 'C' textbook - it will come in useful in deciding which bit to set in which byte of the array...
