Configuring CAPCOM 1 Channel 0 and 1 via DAVE
Hi
I have been trying to set Compare Mode 1 in the CAPCOM1 Channel 0 and 1, unfortunately it wouldn't let me. I am aware that it is disabled because the pin is used alternate input the chip select (CSO_n) but the problem is I don't know how to do it. So I would be very grateful if you give me instruction to disable alternate input and enable channel 0 and 1 running in compare mode 1.
I look forward to hear from you asap
Arron
