Hi all. I am using two Nordic boards to communicate between two PCs using the serial ports. The program I have written works fine if I am using Hyper Terminal to input the characters one at a time. However, my main goal was to be able to send complete strings wirelessly from one PC to another and this is where the problem is. If I try sending a string, some of the characters go missing and never arrive at the receiver. I have included my code below:
#include <Nordic\reg24e1.h> struct RFConfig { unsigned char n; unsigned char buf[15]; }; typedef struct RFConfig RFConfig; #define ADDR_INDEX 8 // Index to address bytes in RFConfig.buf #define ADDR_COUNT 4 // Number of address bytes const RFConfig tconf = //configures the 16 tx bits //tconf rconf { // 0x04 0x05 - 2402MHz Channel 15, // 0x76 0x77 - 2459Mhz Channel 0x08, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xaa, 0xbb, 0x12, 0x34, 0x83, 0x6F, 0x76 }; const RFConfig rconf = { 15, 0x08, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xaa, 0xbb, 0x12, 0x34, 0x83, 0x6F, 0x05 }; volatile unsigned char rxbyte, rxcount,txcount, txbyte,check; void Delay100us(volatile unsigned char n) { unsigned char i; while(n--) for(i=0;i<35;i++) ; } void Init(void) { P0_ALT = 0x06; // Select alternate functions on pins P0.1 and P0.2 P0_DIR= 0x42; // P0.1 input, rest is output PWR_UP = 1; // Turn on Radio Delay100us(30); // Wait > 3ms SPICLK = 0; // Max SPI clock (XTAL/8) SPI_CTRL = 0x02; // Connect internal SPI controller to Radio } void InitRS(void) { TH1 = 230; // 9600@16MHz (when T1M=1 and SMOD=1) (ref page 95 of Datasheet) CKCON |= 0x10; // T1M=1 (/4 timer clock) PCON = 0x80; // SMOD=1 (double baud rate) SCON = 0x77; // Serial mode1, enable receiver(1010010) TMOD = 0x20; // Timer1 8bit auto reload (Page 84 of Datasheet TCON = 0x40; // Start timer1 (01000000) (Page 85 of Datasheet) } void PutChar(char c)//puts a char on the serial port { while (!TI) ; TI = 0; SBUF = c; } unsigned char SpiReadWrite(unsigned char b) //(wirelessly) transmits char b { EXIF &= ~0x20; // Clear SPI interrupt SPI_DATA = b; // Move byte to send to SPI data register while((EXIF & 0x20) == 0x00) // Wait until SPI hs finished transmitting ; return SPI_DATA; } void TransmitPacket(unsigned char b) { unsigned char i; CE = 1; //chip enabled (Activate TX mode) Delay100us(0); for(i=0;i<ADDR_COUNT;i++) SpiReadWrite(tconf.buf[ADDR_INDEX+i]); SpiReadWrite(b); //transmit CE = 0; //chip disabled (disable TX mode) Delay100us(3); // Wait ~300us } void Transmitter(unsigned char c) { unsigned char b; CS = 1; Delay100us(0); for(b=0;b<tconf.n;b++) { SpiReadWrite(tconf.buf[b]); } CS = 0; TransmitPacket(c); // Transmit data } void Receiver(void) { unsigned char b; CS = 1; Delay100us(0); for(b=0;b<rconf.n;b++) { SpiReadWrite(rconf.buf[b]); } CS = 0; CE = 1; Delay100us(100); { if (rxcount > 0) { EX4 = 0; //disable DR1 interupt b = rxbyte; //place recieved data into b rxcount = 0; PutChar(b); EX4 = 1; //enable DR1 interupt } } CE = 0; } void drirq(void) interrupt 10 { EXIF &= ~0x40; // Clear DR1 interrupt rxbyte = SpiReadWrite(0); rxcount = 1; } void main(void) { unsigned char RxChar; unsigned char TxChar; Init(); InitRS(); rxcount = 0; EX4 = 1; // Enable DR1 interrupt EA = 1; // Global interrupt enable for (;;) { if (RI) { TxChar = SBUF; Transmitter(TxChar); RI=0; } Receiver(); } }
I think the problem is due to the 10ms delay I have placed in the receiver. However, if I take this delay out, the receiver never works.
The problem could could possibly be somewhere else but I am not sure.
I appreciate any help.
- Thanks.
Hi Kunal, Instead of polling for serial data in main loop use interrupt based algorithm. Also I see error in using SpiReadWrite function
All the best
