In EcMain.cpp the extern void *operator new(size_t size) fails to allocate memory for a new object on its first invocation. I think that the problem is that _main() is never called, so init_mempool is never called. Does anyone know where the call to _main() is made?
BTW I'm using RTX166
Take a look to: \Keil\C166\Examples\EC++\RtxTiny.
This example shows the setup required for RtxTiny. The RTX166 setup is similar, but RTX166 is replaced now with AR166.
What am I looking for in this example? I still can't see a call to _main(), and the example doesn't dynamically create any objects.
