Is there any way to eliminate uVision 2 splash screen?
I have a build process which invokes uVision 2 from the command line approximately 30 times and runs for around 12 minutes on an AMD 64 X2 3800+.
Each time uVision is invoked, it displays the splash screen, which makes my otherwise perfectly-capable-of editing-at-the-same-time dual core pretty much unusable for the duration of the build.
Does anyone know of a way to eliminate the splash screen, or should I just drink more coffee?
