C166: Call-segmented to a ram-address does not work
I use a ST10F269 (SMALL-modell) with Keil C166 v6.
I try to call a RAM-routine (in XRAM2) from ROM (in Segment 2 => all code is located within 64kB in Segment 2) via assembler routine:
BCLR IEN
CALLS #0,#SOF fls_ram
BSET IEN
fls_ram is a variable at address 0xDBBE
What I expect is, that the call is to address 0xDBBE but it is to address 0x9BBE (14bit address).
When I use:
MOV R4, #SOF fls_ram
it works fine, I have the 16bit-address in register R4 but not with CALLS, JMPS, ..
Are there restrictions for the use of #SOF?
How can I jump to the RAM-area (in a different segment)?
Thanks for the help!
Best Regards,
Josef Aspelmayr
  • Maybe this is not what you are asking but did you try this.
      CALLS #SEG fls_ram, #SOF fls_ram
    Regards,
    Chris
  • Yes,
    I tried:
    The result is the same, segment is 0x0 and address is 0x9BBE and not 0xDBBE..
    What is really strange for me is the fact, that when I use..
    ..I have the correct value in R4 but not when I use CALLS/JMPS.
    Thanks and best regards
    Josef Aspelmayr
  • fls_ram is a variable at address 0xDBBE
    I think you mean routine or symbol?
    Did you double check the map/.m66 file? And the linker file?
    According to http://www.keil.com/support/docs/688.htm :
    This function combines the segment (DPP register) and offset to get a real 16-bit address.
    Could it be that the fls_ram routine is in DPP space and the DPP contains 0? Naah, that doesn't make sense either...
    It -is- weird...
    Good luck!
    Joost Leeuwesteijn
  • fls_ram is a variable (array) in XRAM. I copy the code to XRAM, then I want to start the code. Thats the reason why I call/jump to a RAM-address.
    And the address (0xDBBE) is from map-file..
    Best Regards,
    Josef Aspelmayr
  • I am not sure how you have everything defined in your project. But if I try a sample program everything is working as I would expect.
    unsigned int fls_ram[50];
    extern void MyFunc (void);
    void main(void) {
      fls_ram[0] = 0x00DB;  /* RETS instruction */
      MyFunc();
      for(;;);
    I defined a RAM section from 0x40000--0x4FFFF
    040140H fls_ram VAR --- NDATA0 ?ND0?MAIN
    Here is the assembly file:
    $NOMACRO
    $SEGMENTED CASE
    $MODINF (43)
      NAME MYASM
      NCODE  CGROUP  ?PR?MYASM
      ASSUME  DPP3 : SYSTEM
      REGDEF   R0 - R15
      EXTERN fls_ram:WORD
      ?PR?MYASM  SECTION  CODE WORD 'NCODE'
      MyFunc  PROC  NEAR
      PUBLIC  MyFunc
      RET
      MyFunc  ENDP
      ?PR?MYASM  ENDS
      END
    If you run this code it jumps to the RAM location (0x40140) and then does a RETS, just as expected.
         5: void main(void) {
         6:
         7:   fls_ram[0] = 0x00DB;  /* RETS instruction */
    00020000 E6F4DB00  MOV      R4,#0x00DB
    00020004 F6F44081  MOV      DPP2:0x0140,R4
         8:   MyFunc();
         9:
    00020008 CA000E00  CALLA    CC_UC,MyFunc(0x2000E)
        10:   for(;;);
    0002000C 0DFF      JMPR     CC_UC,0x02000C
        18:   CALLS   #SEG fls_ram, #SOF fls_ram
    0002000E DA044001  CALLS    0x040140
        19:         RET
    Sorry not sure how to help you. Perhaps you can reduce your problem to a small working code snippet then others could look to find the problem?
    Best regards,
    Chris
  • Hello Chris,
    thanks for the help!
    I have tried your code-snippet, but with variable located in XRAM-area:
    00C200H     fls_ram  VAR   ---  NDATA0  ?ND0?TEST
    And it works!
    But I have tried to do the same with #pragma ASM and I get the same failure:
    void MyFunc(void);
    void main(void) {
      MyFunc();
      for(;;);
    void MyFunc(void)
    #pragma ASM
      CALLS   #0, #SOF fls_ram
    #pragma ENDASM
    In that case I have a:
    CALLS 0x8200
    .. so this is wrong!
    Best Regards,
    Josef
  • I left off the reference to the DPP in the extern reference in the separate assembly file.
    It appears the environment always assumes a data access (which it should) and this is why the DPP is causing you an issue (you don't want this).
    If you want to jump to a variable then I would create a function pointer assigned to the data variable address and then call it (keeping everything in C). Here is an example.
    void (far *MyFunc)(void) = (void far *)(&fls_ram[0]);
    void main (void) {
      (*MyFunc)();          /* call MyFunc in XRAM */
      for(;;);
    Best regards,
    Chris
  • Despite the DPP-addressing, the SOF-Operator shall use the 16bit-address (and this should be done with any opcode-variant).
    I was in contact with Keil and according to Support-Team this is a compiler-issue and will be solved.
    Thanks for all the help!
    Best Regards,
    Josef
  • I was in contact with Keil and according to Support-Team this is a compiler-issue and will be solved.
    Seems like you've found a bug! Nice work (reporting it)!
    I was thinking it might help to explicitly declare the fls_ram variable as huge/xhuge in the C file? To make sure it doesn't use near/DPP. But this would generate the same #SOF instruction I guess, not sure.
    Regards,
    Joost Leeuwesteijn
