Problem with Infineon DAvE using C167CRr2 DIP
I have found a problem with the C167CRr2 DIP for DAvE. The #defines in MAIN.H generated by DAvE use a bit-field structure to access SFR bits, rather than just using sbit.
This causes a statement such as
S0TBIC_S0TBIE = 1
to generate code like
MOV R4,0F19CH
BSET R4.6
MOV 0F19CH,R4
rather than
EXTR #01H
BSET S0TBIE
The problem this was giving me was that if the S0TBIR bit becomes set, it can be lost when the second MOV instruction is executed.
I found that the C167 DIP just relies on the reg167.h file, and does not use the bit-field structures. This is how I have worked around the problem, but it will become a pain if I need to use any of the C167CR functionality which does not exist on the basic C167.
I have reported this problem to Infineon who are looking into it, but just thought I would mention it in case it helps anyone, or anyone has any alternative suggestions.
