Using MDK
Hi Guys,
Does someone have experience with porting ARTX (using Keil tool chain) based application to RTX (using Real View/ARM tool chain)?
I am just doing this, and so far I have the following problems:
1) When increasing compilation optimization - some strange behavior of char arrays (one of them is strangely overwritten);
2) When optimization level is set to highest, and is set for "Time optimization" – compilation process hangs (after stopping build, closing the project and uVision Uv3.exe and armcc.exe have to be killed manually via Win Task manager as they keep running);
Does someone have something like that as problems?
Thank you!
Nivelinn
  • The RTX_CONF file needs to be compiled with Optimize 0. Therefore all RealView configuration (that come with MDK 3.01) have the #pragma O0 included in this file.
    Other RTX source files can be fully optimized, but the config file contains the context switch which is a bit tricky from the compiler optimization point of view.
    Note again, that all current versions are correctly configured.
