I'm trying to use the exec function to set a breakpoint which results in a function call. The same BS statement is fine when used outside of an exec call.
Ex:
BS REGNAME,1,functionname() <- works fine
FUNC void somefunction(void) { BS REGNAME,1,functionname() <- "Literal expected" error. }
Is this a limitation of the software? I don't see any such restrictions listed in the help file for exec.
http://www.keil.com/support/man/docs/uv3/uv3_df_exec.htm
