using the "_at_" keyword in some case mess up variable storage
it seems that using "_at_" keyword with extern variables does not work well.
The code below shows what I wish to share with you guys.
sample.c:
xdata volatile unsigned char xdata_var_bad _at_ 16;
xdata volatile unsigned char xdata_var_ok _at_ 16;
void test( void )
  xdata_var_bad = 0;
  xdata_var_ok = 0;
sample.h:
extern xdata volatile unsigned char xdata_var_bad _at_ (16);
extern xdata volatile unsigned char xdata_var_ok;
main.c:
#include "sample.h"
void main(void)
	xdata_var_bad =0;
	// disassembly for above assignment is:
	//		MOV	 DPTR,#0x0000
	//     		MOV      A,#0
	//		MOVX     @DPTR,A
	xdata_var_ok =0;
	//		MOV	 DPTR,#0x0010
	//     		MOV      A,#0
	//		MOVX     @DPTR,A
Any commment ?
Boris
