problems about the internal memory writing
Hi all,
I'm using the AT91SAM7S64 chip on the Evaluation Board AT91SAM7S-EK, and I'm trying to write the internal flash rom.
The code that I use is the follow:
unsigned int dato = 0xAABBCCDD;
unsigned int address = 0x00100000;
int page = 20;
AT91F_Flash_Init();
AT91F_Flash_Write_Page(address, dato);
void AT91F_Flash_Init (void)
AT91C_BASE_MC->MC_FMR = ((AT91C_MC_FMCN)&(72 <<16)) | AT91C_MC_FWS_1FWS;
int AT91F_Flash_Ready (void)
int status;
status = 0;
//* Aspetto la fine del comando
while ((status & AT91C_MC_FSR_FRDY) != AT91C_MC_FSR_FRDY )
status = AT91C_BASE_MC->MC_FSR;
return status;
int AT91F_Flash_Write_Page(unsigned int Flash_Address, unsigned int buff)
AT91PS_MC ptMC = AT91C_BASE_MC;
page = 510;
Flash = (unsigned int *) Flash_Address;
*Flash = buff;
//* Do il comando di scrittura
ptMC->MC_FCR = AT91C_MC_CORRECT_KEY | AT91C_MC_FCMD_START_PROG | (AT91C_MC_PAGEN & (page <<8)) ;
status = AT91F_Flash_Ready();
return (1);
My program haven't problem when I perform a debug step-by-step; instead my program doesn't work (go to "crash" !!!) when I try to run it.
Could you hel me? Thanks.
