Hi everyone, is there anyone who could help me with following? In x51 processor You have SBUF buffer which is used to send or receive a character via serial port. Is there any way to send a string? Not only a single character, but whole string? I thought there could be any library which deals with it. Or do I have to write it myself? I'm using Keil of course. Would You be so kind and help?
I thought there could be any library which deals with it.<p> Yes ! You thought right, and a quick look into the C51 compiler documentation will reveal what you are looking for: http://www.keil.com/support/man/docs/c51/c51_lib_stream.htm
Indeed, I was looking for this one. Thanks ;-).
Of course, nothing will keep you from coming up with your own code to tackle this. Implementing a software FIFO for the UART can be a very educational experience, because it will deal with many of the issues found in more complex uC software - reentrancy, interrupts, memory constraints and so on.
I've got a problem.
static void Nastav_seriovy_kanal (void) { SCON = 0x50; TMOD = TMOD | 0x20; TH1 = 0xF4; TL1 = 0xF4; ES = 1; TR1 = 1; } static void Preruseni_seriovy_kanal (void) interrupt 4 { if (RI == 1) { RI = 0; if(SBUF == 'A') putchar('Q'); } if (TI == 1) TI = 0; }
ATMEGA32:
//------------------------------------------------------------------------------- // Zinicializuje UART void Serial_Init() { // Set baud rate UBRRH = 0; UBRRL = 71; // 9600baud @ 11.0592MHz UCSRB=(1<<RXCIE)|(1<<RXEN)|(1<<TXEN); // povolim RX, TX a preruseni od RX UCSRC=(1<<URSEL)|(3<<UCSZ0); // D=8, P=0, S=1 } //--------------------------------------------------------------------------------- // signal handler for receive complete interrupt SIGNAL(SIG_UART_RECV){ char aku; int temp, h, l; aku=UDR; ... } //--------------------------------------------------------------------------------------------- void PutStr(char *p){ // Posle string while (*p) { PutChar (*p++); } }
"ATMEGA32" Why are you posting AVR code for a non-Keil compiler?? That's almost entirely irrelevant, since issues related to Port IO and interrupts a almost entirely target- and compiler-specific! Keil does not have a SIGNAL macro or keyword - and it's deprecated in AVR-GCC anyhow!
I think the SIGNAL is a debugger thing, for generating code that runs to simulate event for the controller.
"I think the SIGNAL is a debugger thing for generating code that runs to simulate event for the controller." Yes, uVision has "Signal Functions" - but that was not uVision syntax. It was definitely AVR source code - he said so himself: "ATMEGA32" (that's an AVR)
Hi, the point was the while loop sending string to USART. Sorry... Mirek
