Hi All,
I am trying to add WTD reset to my application. I am working exactly like keil watchdog example.
The problem is that it looks like the feeding routine is not working properly. I receive wtd reset every although I manage to feed before time.
My WTD routines are:
void WDTInit(unsigned int WDT_time) {
if (!WDT_time)
WDTC = WDT_TIME_SCALE_VALUE * 1000;
else
WDTC = (WDT_time * WDT_TIME_SCALE_VALUE);
#if DEBUG
WDMOD = WDEN; /* Reset on timer */
#else
WDMOD = (WDEN | WDRESET);
#endif
WDFEED = 0xAA; /* Feeding sequence */
WDFEED = 0x55; }
void WDTFeed( void ) {
WDFEED = 0xAA;/* Feeding sequence */
WDFEED = 0x55;
I will be glad if someone can help
Regards Kobi
hi,
could you please tell me what kind of device do you use ?
Regards,
giovanni
