Hi all, I want to link the port P9 to a LCD with a 80C509. I have already linked a keyboard to the port P4 and I manage to declare a bit with this instruction: sbit P4_0 = P4^0; but when I try the same thing whit P9, the compiler says to me: P9 : invalid base adress I think it's because P9 is not bit adressable but I'm not sure. So I try to read the value of P9 with this instruction: unsigned char val = P9; but the compiler says: error C247: non-adress/-constant initializer It seems that P9 is a constant, I can read its value but I can't change it. Is someone who know how to do to change the value of P9? Thanks. ps: Sorry for my bad english, I'm a french student ;-).
Maybe the SFR that controls P9 is not declared yet. Refer to the processors datasheet for the appropriate SFR address, and declare the P9 sfr yourself. http://www.keil.com/support/man/docs/c51/c51_le_sfr.htm
Sorry I forgot to say that I use the library "reg509.h" and the sfr of P9 is declared inside. When I declare the sfr myself it says: error C231 : 'P9' : redefinition I don't understand why P9 is a constant whereas P0, P1, P2, P3, P4 and P5 can be modified?
but when I try the same thing whit P9, the compiler says to me: P9 : invalid base adress Is the SFR address of P9 divisible by 8? Erik
No, the adress of the SFR is 0xF9 so it's not divisible by 8. What does it mean?
then it is not bit addressable Erik
Ok, thanks Erik. And do you know why it's a constant?
#include <reg52.h> unsigned char global_val = P0; void main (void) { unsigned char local_val = P0; }
Thanks for the info Mr Neil. I found a solution. I have just written:
void main (void) { P9 = 0x5F // 0x5F is an example }
