Redifinition Error
Dear all,
I have compiled the following program and am getting redifinition error. I have not redifined the function anywhere, Please help.
Following is my code:
// SFR description needs to be included
#include <reg932.h>
#include "timer.h"
#include "eeprom.h"
#include "port.h"
// flag that indicates if the EEPROM is busy or not
//static bit meeprombusy;
//bit bdata flags;
//s/bit combit = flags^0;
//extern bdata int combit flags;
//** Main Program ** //
void main(void)
interrupt_enable();
ports_init();
eeprom_init();
eeprom_initread();
if(DEEDAT =! 0)
timers_init();
else
eeprom_readloc1();
eeprom_readloc2();
eeprom_readloc3();
eeprom_readloc4();
loadvalues
timers_starttimer0();
timers_stoptimer0();
DESC: Initializes timers
Timer 0 generates an interrupt every 1s
Timer 1 is not used
RETURNS: Nothing
CAUTION: If interrupts are being used then EA must be set to 1
after calling this function
void timers_init (void)
// configure timer 0
TMOD &= 0xF0;
TMOD |= 0x01;
TAMOD &= 0xFE;
// timer values
TH0 = 0xff;
TL0 = 0xfe;
// set timer 0 isr priority to 0
IP0 &= 0xFD;
IP0H &= 0xFD;
// enable timer 0 interrupt
EA = 1;
ET0 = 1;
// start timer 0
TR0 = 1;
} // timers_init
DESC: Timer 0 Interrupt Service Routine
RETURNS: Nothing
CAUTION: timers_init must be called first
EA must be set to 1
void timers_isr0(void) interrupt 1 using 1
// reinitialize
TH0 = 0xC0;
TL0 = 0x00;
DESC: Starts timer 0
RETURNS: Nothing
void timers_starttimer0(void)
TR0 = 1;
} // timers_starttimer0
DESC: Stops timer 0
RETURNS: Nothing
void timers_stoptimer0 ( void )
TR0 = 0;
} // timers_stoptimer0
DESC: Initializes the EEPROM. Enables EEPROM interrupt
RETURNS: Nothing
CAUTION: Set EA to 1 after calling to enable all interrupts
void eeprom_init
void
// initially eeprom is not busy
meeprombusy = 0;
// set isr priority to 0
IP1 &= 0x7F;
IP1H &= 0x7F;
// enable eeprom interrupt
EIEE = 0;
unsigned char eeprom_initread
unsigned int address // 9-bit address to read (0x000 - 0x1FF)
// wait for previous operation to complete
while (meeprombusy);
// eeprom now busy
meeprombusy = 1;
// store bit 8 of address
// byte operation, clear interrupt flag
DEECON = (address >> 8) & 0x01;
// store bits 0-7 of address
DEEADR = address & 0xFF;
// if not using interrupt then poll for end of operation
if (!EA || !EIEE)
// wait for operation to complete
while (!(DEECON & 0x80));
// eeprom no longer busy
meeprombusy = 0;
// return value
return DEEDAT;
return 0x00;
unsigned char eeprom_readloc1
// eeprom now busy
meeprombusy = 1;
if (!EA || !EIEE)
meeprombusy = 0;
// return value
return DEEDAT;
return 0x00;
void interrupt_enable (void)
EA =1;
EX0 =1;
ET0 =1;
void ports_init
void
P0M1 &= 0xFE;
P0M2 &= 0xFE;
P1M1 |= 0x28;
P1M2 &= 0xD7;
P3M1 |= 0x03;
P3M2 &= 0xFC;
} // ports initialisation
  • I have compiled the following program and am getting redifinition error.
    Please post the exact error message. Copy and paste it, do not retype it.
    Which function ?
    Enclosing the source code tags
     and
    will make it much more readable.
  • The source code tags are [less-than sign]pre[greater-than sign] and [less-than sign]/pre[greater-than sign].
    Apparently, the board does not let you post these tags, even when using &_gt; and &_lt; (minus the underscore). It did work in the preview, but the posting got messed up.
  • Following is my code:
    #include <reg932.h>
    #include "timer.h"
    #include "eeprom.h"
    #include "port.h"
    What's in all these .h files ?
    //bit bdata flags;
    void main(void)
    interrupt_enable();
    Ok. I did not see a prototype for this function. Is it in one of those .h files or is it simply missing ? If this is the first time the compiler sees interrupt_enable();, it will think that it is a function definition.
    ports_init();
    eeprom_init();
    eeprom_initread();
    if(DEEDAT =! 0)
    timers_init();
    else
    eeprom_readloc1();
    eeprom_readloc2();
    eeprom_readloc3();
    eeprom_readloc4();
    Ok. What _should_ this code do ? It looks like it should call timers_init(); if DEEDAT is not equal to zero, else call eeprom_readloc1();, eeprom_readloc2();, eeprom_readloc3(); and eeprom_readloc4();. Right now, it's probably going to give you a syntax error ("=!" instead of "!="), and then, it is going to call timers_init(); if DEEDAT is not equal to zero, else call eeprom_readloc1(); and then always call eeprom_readloc2();, eeprom_readloc3(); and eeprom_readloc4();. Also, where are the prototypes for all these functions ? The compiler sees them for the first time and will assume they are implied function definitions.
    loadvalues
    All this does is give you some kind of syntax error. Did you mean loadvalues(); ?
    More functions without prototypes.
  • Hi,
    It seems i forgot to protype all the functions. The .h files are bit addresses for the sfrs as the name suggests :
    "reg932.h" - for 89LPC932 sfrs required for initialisation.
    "timer.h" - for timer0 (timing for 1 second)
    "eeprom.h" - for eeprom (eeprom read, write)
    "port.h" - for port 0,interrupt0 initialise sfrs
    I need the timer to count 1 second and using the registers i want to count 500hrs. during power fail through a PF0 interrupt generated by TPS3707 on a External interrupt.
    I am also using the code architect for the same.
    Thanks and regards,
    Aniket
  • actually without a prototype you can get 2 messages "proto required" and on next call "redifinition"
