Unsigned short subtraction
I don't know what the ANSI/ISO C standard says about this, but I would expect the if block in the example below to be executed when a is 0 and b is 65535:
/* a and b are unsigned short (16 bits). */
if( (a - b) < 10)
    do something
The block is not executed because the comparison of (a - b) with 10 is done without first resetting the upper 16 bits of the result to 0 (actually comparing two 32 bit unsigned int). Same problem with unsigned char. Sauli
