GNU toolset prob LD/collector2
i am having problems getting the GNU tools to run under
Keil. It is not the well-known problem of the CGWIN path
or the arm-uclibc- prefix. Compiler and assembler do
their work, but when the linker gets engaged, i get a
message
collect2: cannot find 'ld'
collect2.exe itself, when started from a dos box, gives a
"cannot find ld".
Even remaining arm-uclibc-ld.exe to ld.exe and beyond that
copying it into the
c:\Cygnus\arm-tools\lib\gcc-lib\arm-thumb-elf\e.3.1 dir
side by side to that collect2.exe did not help.
I have worked some hours through the GNU docs, that i have
here and have tried some solutions, eg setting an environment
variable COLLECT_NO_DEMANGLE did not help.
To be honest, i am "a bit" fighting in the fog with the gnu
tools and just at the very beginning of some understanding.
Though i like them the more i learn about it..
I do have various gnu tollsets on my PC, but don*t see any
cross-effects and even hiding/renaming their dirs did not help.
(Win32 / CrossStudio Eval / CodeSourcery GNU Toolchain)
BTW:
The "links" in the c:\Cygnus folder do look quite strange,
seemingly being no standard windows links. Checking the
properties of the links to executables reveals empty fields
for targets and working directories. Looking at their
content comes up with e.g.
../../bin/arm-uclibc-gcc.ex
C:\cygwin\arm-tools\bin\arm-uclibc-gcc.exe
though the dir is clearly not c:\cygwin bit c:\Cygnus.
Maybe a specialty from the ?company? Cygwin? for their
product ?cygnus?
I have not fiddled around with some homemade project. This
happens with the unmodified hello project from
\ARM\GNU\EXAMPLES\hello
But to cut the story short:
What can i do to get it to work?
(Using Keil uVision 3 v3.21 ARM evaluation)
Finally a big thanks to whom deserves:
The Keil CD is so full of useful information, datasheets
and an extremely generous handling of the evaluation
policy for the IDE and tools, that the Keil people deserve
a strong applause. Useless to translate my feeling to
english ("mir blieb die Spucke weg").
Though some details could be worked out a bit (for beginners?),
mostly regarding the help (C51/ARM mangling) and some tricks, eg.
the possibility to write an ini file for the debugger/simulator
and what to put into that. I have spent some time in manually
opening the memory range in the simulator before i found that.
Great work!
Greetings
Eric
PS:
Probably someone will ask, why i don't simply use the Keil
toolset. I would like to do so, and will do for pure assembly
projects... but for C projects the Keil tools won't work in
this case, because i am (mis)using an oldtimer ARM from around
1995, a model 2 or 2A and it doesn't know anything about CPSR
and SPSR registers or BX commands.
To answer the next question, why i am using that oldie:
1) because i have it
2) i like the challenge
3) there is a lot of hardware on that board, that can not
be found on any development board. (ISDN equipment)
I have been tempted of "cracking" into the keil libraries
and exchangig those little beasty parts in the code, but it
would probably take some days to find the right places and
it might be a case where Keil would not be amused of..
retro-cracking their software ... ;)))
  • I have just seen that i wrote
    > I do have various gnu tollsets on my PC, ...
    Yes, the germans have some unbeatable faible for tolls,
    that can not be hidden all the times ...
    I hope that is not a bad omen for my question.
    The german tollcollect desaster comes to my mind ;;)
    Maybe ..
    a GNU toll would fit the german politician_apparatschiks?
    Greetings
