In Examples or help void os_evt_set (U16 event_flags, OS_TID task); #include <ARTX.h> void task1 (void) __task { . . os_evt_set (0x0003, tsk2); . . } #include <ARTX.h> void task1 (void) __task { OS_RESULT result; result = os_evt_wait_or (0x0003, 500); if (result == OS_R_TMO) { printf("Event wait timeout.\n"); } else { printf("Event received.\n"); } . . } I see C:\Keil\ARM\ARTX\Examples\Traffic project but how to define value of flags? os_evt_set (0x0002, t_command); what why ? 0x0002? os_evt_clr (0x0003, t_command); what 0x0003 ? -------------------------------------------- void keyread (void) __task { while (1) { /* endless loop */ if ((IOPIN0 & key) == 0) { /* if key pressed */ os_evt_set (0x0010, t_lights); /* send signal to task lights */ } os_dly_wait (5); /* wait for timeout: 5 ticks */ } } --------------------- os_evt_set (0x0010, t_lights) 0x0010 why? Table of event_flags,wait_flags? thank you
Event Flags are bits that you can freely define. The values represent bit-masks. Reinhard
Thank you
