Library help!
Hello. I need a little help trying to create a "library" or a "library in a project". A couple questions:
How do you create a stand alone library?
And with the following text from the knowledge database, how do you add a second target in uVision?
"Add for the library an own target and and an own file group to your project. For example, add the target Library and file group Library."
  • like this
    if not exist as.lib goto usliex
    del as.lib
    :usliex
    c:\tools\keil\c51\bin\lib51 c as.lib					>..\trash\trashbin
    c:\tools\keil\c51\bin\lib51 a Sacode.obj	to as.lib	>..\trash\trashbin
    c:\tools\keil\c51\bin\lib51 a Sccode.obj	to as.lib	>..\trash\trashbin
    c:\tools\keil\c51\bin\lib51 a SSF881C.obj  	to as.lib	>..\trash\trashbin
    c:\tools\keil\c51\bin\lib51 a SSF882C.obj  	to as.lib	>..\trash\trashbin
    c:\tools\keil\c51\bin\lib51 a SSF882M.obj  	to as.lib	>..\trash\trashbin
    c:\tools\keil\c51\bin\lib51 a SSFcc1C.obj  	to as.lib	>..\trash\trashbin
    c:\tools\keil\c51\bin\lib51 a SSFcc1A.obj  	to as.lib	>..\trash\trashbin
    c:\tools\keil\c51\bin\lib51 a SSF771A.obj  	to as.lib	>..\trash\trashbin
    c:\tools\keil\c51\bin\lib51 a SSF901C.obj  	to as.lib	>..\trash\trashbin
    c:\tools\keil\c51\bin\lib51 a Scrout.obj  	to as.lib	>..\trash\trashbin
    c:\tools\keil\c51\bin\lib51 a Sarout.obj  	to as.lib	>..\trash\trashbin
    c:\tools\keil\c51\bin\lib51 a Sfmtbs.obj  	to as.lib	>..\trash\trashbin
  • "How do you create a stand alone library?"
    Errr... isn't that a contradiction in terms?
    A library does not stand alone: it needs to be linked to other stuff to create a useful program that can stand - or, rather, run - alone.
    Did you consider checking the 'Create a Library' box on the 'Output' tab of the Project options...?
    Library Manager Manuals:
    http://www.keil.com/support/man/docs/lib51/
    http://www.keil.com/support/man/docs/libx51/
  • if not exist as.lib goto usliex
    del as.lib
    :usliex
    Or, more simply,
    if exist as.lib del as.lib
    or did you just want an excuse to use a dreaded goto?! ;-)
    del as.lib
    :usliex
    Or, more simply,
    How did you guess? :)
    1) I have absolutotally no problem with goto in .bat files, very little can be done without it.
    2) Without "proof" I would say that the construct is from a time when more was there. This file is a modified copy of a modified copy of a modified copy of a modified copy of .....
  • I was refering to this useless bit of info: http://www.keil.com/support/docs/2610.htm
    What "create a library" on the project tab? I'm using uVision3. Obviously I'm missing some piece of information.
