I have a problem like this. I have mixed ASM and C source code. After compiling when I look LST file where is a code made by CA it looks like bellow. And it is good for me. Function is called by direct BL.
263: mem_cpy(SubExt, ptrByte, bLength); 00000120 1C28 MOV R0,R5 ; bLength 00000122 0602 LSL R2,R0,#0x18 ; bLength 00000124 0E12 LSR R2,R2,#0x18 00000126 A800 ADD R0,R13,#0x0 00000128 1C21 MOV R1,R4 ; ptrByte 0000012A F7FF BL mem_cpy?T ; T=0x0001 (1) 0000012C FF69 BL mem_cpy?T ; T=0x0001 (2)
263: mem_cpy(SubExt, ptrByte, bLength); 000001C4 1C28 MOV R0,R5 ; bLength 000001C6 0602 LSL R2,R0,#0x18 ; bLength 000001C8 0E12 LSR R2,R2,#0x18 000001CA A800 ADD R0,R13,#0x0 000001CC 1C21 MOV R1,R4 ; ptrByte 000001CE 4B44 LDR R3,[R15,#272] ; PoolRef @0x2E0 ; mem_cpy?T 000001D0 F000 BL L_53 ; T=0x01D6 (1) 000001D2 F801 BL L_53 ; T=0x01D6 (2) 000001D4 E000 B L_54 ; T=0x000001D8 000001D6 L_53: 000001D6 4718 BX R3 000001D8 L_54:
I don't know about the ARM tools, but with C51 this would be due to the Linker optimisations. That's why the linker produces a separate COD file - because it will be different from the compiler/assembler-generated code in the LST files! Does your linker do post-compile optimisation? Can you turn it off?
Thanx about answer :) I'm using Keil ARM tools (CARM,AARM,LARM) 2.42 and uVision 3. I have tried all optimization levels and other options what uVision can offer but without any change. I have also checked CARM,AARM,LARM online manuals. When I call standard memcmp functions from string.h or other functions in C sources everything is ok after linking.. But if I try call any of my function in ASM sources from C it will be converted to this "Indirect Call" look. I have also tried several different function prototyping for ASM functions like:
//#define EXTERN extern //#define EXTERN const //#define EXTERN //#define ADDRESS(addr) __thumb __at addr; //#define ADDRESS(addr) __thumb; //#define ADDRESS(addr) ; EXTERN void *mem_cpy(void *Dest, const void *Source, unsigned int length) ADDRESS(ROM_MEM_CPY)
It looks like your mem_cpy() function is located at an address out of the 4M (thumb) or 32M (arm) branch range. In this case, the linker automatically creates an address veneer. This is required to 'enlarge' the branch-range to the full address range, so the code is correct and absolutely required here. The compiler does not necessarily see this condition, therefore the code listing must be considered as preliminary. The linker finalizes the code and also gives a .cod listing which reflects the final generated code. Peter
