friends,i have interfaced 512k nvram to 89c668 (philips) but i dont know how to declare variables to xdata and xram.Is there any keyword to define variables seprately in xdata and xram at compile time.
____following variable i am defining in nvram
unsigned long int xdata sector_location _at_ 0x0001; int xdata sector_number _at_ 0x0005; unsigned char xdata starting_info[10] _at_ 0x0007; unsigned char xdata memory_space[65535] _at_ 0x0000; unsigned char xdata check_location _at_ 0x0030; unsigned char xdata ce_overflow _at_ 0x0027; ;
while 89c668 has 8k xram space that memory(all) also i want to store variables.
but because my array memory_space[65535] excceding xdata space .i cannot define more variables,it give s me xdata space overflow error. hence if i have to define variables every time i have to use _at_ and addressed according to bytes.
like data char SendInst[500] _at_ 2098; xdata char SendCBill[50] _at_ 2598; xdata char SendDK[200] _at_ 2648; xdata char temptamper[40] _at_ 2840; xdata char SendTamper[40] _at_ 2880; xdata char TP1[10] _at_ 2920; xdata char TP2[10] _at_ 2930; xdata char CB[10][150] _at_ 2940; xdata char DIALnumber[15] _at_ 3090; xdata char SMSnumber[15] _at_ 3105 ; xdata char Usernumber[15] _at_ 3120 ; xdata char Inbox[200] _at_ 3135 ; this gives me warning overlapped areas but my code runs.
i am using smallmemory model and i dont want to declare all variable in nvram(except declare first). plz help me.....
"Is there any keyword to define variables seprately in xdata and xram at compile time."
No - because they are one and the same thing, as far as the 8051 instruction set is concerned!
"XDATA" and "XRAM" both mean just "memory addressed by the MOVX instruction"
Actually, you do know that --- the examples you show demonstrate that nicely (although you use _at_ a bit too much, IMHO).
Your problem is a different one: xdata can only reach 64 KiB, so it can't be the solution for accessing those 512 KiB. Be a brave person today: open your manual and look up "far" and "xdata banking" in the index.
