Hello, i'm working on a project where I have to use the LCD and two LEDs at the same time. LCD is commonly on Port 3. So the LEDS are ! LCD will use 7 bits from the port 3, and both LEDs will use one bit each. The problem is that the port is 8-bit. Can I use the LCD on another port, for the example Port 1 ? (Silicion laboratories tells that we should use 4 bits of data on the Port 1). If it is effectively possible, how should I proceed ? Or, can I use LEDs on another port ? Then, how to initialize the port to handle the LED_Block.
Can I use the LCD on another port I think I do not understand the question. Why would you ask "Can I use the LCD on another port". Any port pin (p3-P1) is identical and P0 with pullups added match the rest. Erik
How can I use the LCD on port 1 for data and port 3 for EN, RS and RW ? What do I need to do ?? thank you Gio
address the pins you use
can you be more explicit please ?? an example would be welcomed. I 'm a novice, I know...
if you want LCD data on Px, then asm: mov Px,variable_that_hold_data_to_ be outpout c: Px = variable_that_hold_data_to_ be outpout; Erik PS if you are asking: how do I make some code I have change the port it uses, post the code, It is almost as if you think that all LCDs are connected to the same port
This is my problem, I want to use 2 LEDs and the LCD, but my LEDs work on port 3 and the LCD too. I have to use 9 pins, but I have only 8. So I tried to use port 1 but it doesn't work... sbit LCD_D7 = P1^7; sbit LCD_D6 = P1^6; sbit LCD_D5 = P1^5; sbit LCD_D4 = P1^4; sbit LCD_EN = P3^2; sbit LCD_RW = P3^1; sbit LCD_RS = P3^0; sbit LED0 = P3^3 ; sbit LED1 = P3^4 ; PRT0CF |= 0x40; // Enable TX0 as a push-pull output PRT1CF |= 0x40; // Enable P1.6 (LED) as push-pull output PRT2CF = 0x00; // Enable Port2 as input P2= 0xff; PRT3CF = 0xff; // Enable Port3 as push-pull output I'm sorry but I'm really a beginner with C8051...
sbit LCD_D7 = P1^7; sbit LCD_D6 = P1^6;......... I doubt data is moved to the LCD bitwise PRT0CF |= 0x40; // Enable TX0 as a push-pull output This does not exist on a standard '51 what derivative fdo you use. "in my previous post I asked: "if you are asking: how do I make some code I have change the port it uses, post the code" There is no such in your answer.
