How to enable viewing of enum values from the debugger
Hi, Is there an option to enable viewing of enum values in the debugger?
For example,
typedef enum {false=0, true} FalseTrueType;
In the c souce...
FalseTrueType MyEnumFlag = false;
I would like to view this in the debugger watch window.
Name Value
MyEnumFlag false
but I can only view it as (not Symbolically)
Name Value
MyEnumFlag 0
Thanks, Chris
  • Just to add my two cents to the wish, I find it's often useful to be able to see the actual value as well as the symbolic value. So how about a debugger display such as:
    someEnum: false(0)
    so that we can see both at once, rather than just symbol or value?
  • "So how about a debugger display such as:
    someEnum: false(0)"
    Just noticed that Borland does, in fact, do exactly this!
    I suspect the Keil (C51, at least) doesn't generate debug info for this - so the debugger can't display it.
    (maybe it's a limitation of OMF...?)
  • Hello Chris.
    Sorry that I am answering to this question, but I have seen that you have answered another question. Do you speak german? I am writing with reference to the Application Note "XC16x In-Application On-Chip Flash Programming". I am working with the XC167CI and I have to save data to the on chip flash. I don't know how to configure the memory. The message Adress space out of range always appears.
    Do you have an example code which would work on my µC and how can I read out the stored data?
    Thanks in advance.
    Regards,
    Walter
    (you can contact my through walterbader(at)aon.at)
