i'm programming with the easyweb example. I have made an active connection and tried to send data to a windows socket.
This is my main loop:
while (SocketStatus & SOCK_ACTIVE ) // read the quote from memory { // by using the hardware-debugger DoNetworkStuff(); if (SocketStatus&SOCK_DATA_AVAILABLE) //Receive function { TCPReleaseRxBuffer(); }
if (SocketStatus & SOCK_TX_BUF_RELEASED) { //Send function memcpy(TCP_TX_BUF, Testdaten,800); TCPTxDataCount = 800; //sizeof(Testdaten); TCPTransmitTxBuffer(); // xfer buffer }
If the memcpy function and the TCPTX_DataCount are set in the receive loop and the controller gets information the transfer speed to the pc is up to 170kb/s . If the memcpy function and the TCPTX_DataCount are set as shown in the Send function the Transfer Rate ist only up to 4kb/s.
Why does this happen?
Björn
See: http://www.keil.com/forum/docs/thread8357.asp
Do you have any documentation and sample program about ethernet communication with STR91FW44. I am sending data from MCBSTR9 to PC (Visual Basic Winsock) But datas didnt came until reset or I think transmit buffer reaches 255 char size. I couldnt understand. When MCB program execution is slowed or more delay is added, datas come properly.
