I'm using code banking for my project with the following settings: Memory model: Small: variables in DATA Code rom size: Large: 64K program code banking checked with bank area: start: 0x8000 end:0xffff far memory type support set to create a .hex file The project compiles fine and a .hex file is generated, however this file is empty! If I don't use code banking the correct file is generated. If I use code banking but set the start: 0x0000 and end: 0xffff the file is also generated. but the start has to be 0x8000. Any idea what could be wrong? Thanks in advance for any suggestion.
radu
Is just the HEX file empty or does the application also not load into the debugger. Do you get any other linker/compiler errors/warnings?
Thanks for your reply,
When compiling and linking everything seems fine, there are no errors being reported and I can see that the .hex file is being updated but the only code inside is: ":00000001FF" This happens if I use code banking in conjunction with "merge 32k hex files". If I don't check the merge option the hex file is generated fine.
regards radu
