About on-chip ADC of ST3434E
Hi, everyone: Does anybody has used ST3434E before? The easiset ADC gets me confused. Following is my code:
#include <ST/upsd3400.h>
#include "DATATYPES.H"
#include "ADC.h"
sfr16 ADAT      = 0x95;
sfr16 P1SFS     = 0x8e;
#define ADC_ENABLE      0x20
#define ADC_START       0x02
#define ADC_BUSY        0x01
#define ADC_WORK        (ADC_ENABLE | ADC_START)
VOID ADC_Init(VOID)
        P1SFS   |= 0x0101; // ADC channel 0
        //P1SFS0        = 0x01;
        //P1SFS1        = 0x01;
        ACON    = ADC_ENABLE;// ADC enable, interrupt disable, channel 0
WORD ADC_Read(VOID)
        ACON = ADC_START;
        while (!(ACON & ADC_BUSY)); // wait until ADC is not busy
        //ACON &= ~ADC_ENABLE;
        return (ADAT);
The bit 0 of ACON is status flag, when it is set to 1, the AD conversion completed. But it is never set!
Keil 8, JTAG debugger
  • ADC spec:
    Table 89. ACON Register (SFR 97h, Reset Value 00h)
    Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0
    AINTF AINTEN ADEN ADS2 ADS1 ADS0 ADST ADSF
    Details
    Bit Symbol Function
    7 AINTF
    ADC Interrupt flag. This bit must be cleared with software.
    0 = No interrupt request
    1 = The AINTF flag is set when ADSF goes from '0' to '1.' Interrupts CPU when both
    AINTF and AINTEN are set to '1.'
    6 AINTEN
    ADC Interrupt Enable
    0 = ADC interrupt is disabled
    1 = ADC interrupt is enabled
    5 ADEN
    ADC Enable Bit
    0 = ADC shut off and consumes no operating current
    1 = Enable ADC. After ADC is enabled, 16ms of calibration is needed before ADST Bit is
    set.
    4.. 2 ADS2.. 0
    Analog channel Select
    000 Select channel 0 (P1.0)
    001 Select channel 0 (P1.1)
    010 Select channel 0 (P1.2)
    011 Select channel 0 (P1.3)
    101 Select channel 0 (P1.5)
    110 Select channel 0 (P1.6)
    111 Select channel 0 (P1.7)
    1 ADST
    ADC Start Bit
    0 = Force to zero
    1 = Start ADC, then after one cycle, the bit is cleared to '0.'
    0 ADSF
    ADC Status Bit
    0 = ADC conversion is not completed
    1 = ADC conversion is completed. The bit can also be cleared with software.
  • I know little about this device, but by simply looking at your code, wouldn't
    ACON = ADC_START;
    clear ADEN and disable the ADC? I think perhaps better would be:
    ACON |= ADC_START;
    Also, are you delaying 16ms after first enabling the ADC?
    #include "ADC.h"
    sfr16 ADAT      = 0x95;
    sfr16 P1SFS     = 0x8e;
    #define ADC_AINTF       0x80
    #define ADC_AINTEN      0x40
    VOID ADC_Init(VOID)
            P1SFS   =       0x0101; // ADC channel 0
            //P1SFS0        =       0x01;
            //P1SFS1        =       0x01;
            //ACON  =       ADC_ENABLE;// ADC enable, interrupt disable, channel 0
    WORD ADC_Read(VOID)
            DWORD i;
            ACON    &=  0xE3;                   // choose channel 0
            ACON    |=      ADC_ENABLE;             // enable and start ADC
            for (i = 0; i < 1000000L; i++);
            ACON    |=      ADC_START;
            return ADAT;
    But the bit 0 of ACON is never set either.
  • And you've enabled the conversion clock in ADCPS?
  • I don't touch the ADCPS. I try it immediately.
  • OK, it's gonna work! Thank you very much. Stupid me!
  • Glad to hear it. Then I'm done for the night.
  • It's so kind of you. Wish you have a good night.
