Handling DPP register for variables in different classes
Hi All,
I would like to know, How to handle DPP register for variables in different segments.
For Example
Assume that, I have defined class section as
NCODE(0xC00000 - 0xC0FFFF),
NCONST(0xC0000 - 0xC007FF),
NDATA(0xCOOO - 0xFDFF),
IDATA(0XE00000 - 0xE007FF),
SDATA(0XE00000 - 0xE007FF)
Memory model used is Small
char idata a;
char b;
Variable a is placed in IDATA segment and Variable b is Placed in NDATA segment.
when i try to use both variable are using
(For example b = a;) the same DPP register
is used for assing both variables.
some data from segment NDATA and copy it into variable 'b'.
How can i configure the DPP register for NDATA and IDATA.
Thanks in Advance
With Regards
Ashok kumar p
  • I don't think that you can place IDATA and SDATA to 0xE00000. 0xE00000 - 0xE007FF is occupied by the PSRAM. This memory (Program / Data SRAM) must clearly be distinguished from the internal RAM - access to it is also slightly slower than to the internal RAM. You could define
    IDATA(0xCOOO - 0xFDFF),
    SDATA(0xCOOO - 0xFDFF),
    FDATA(0XE00000 - 0xE007FF),
    HDATA(0XE00000 - 0xE007FF)
    and thus
    char idata a;
    char b;
    char huge c;
    a = b; // should now work
    b = c; // should also work
